rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Where does this switch go?
Recently installed new tunnel lines and this piece came off the heater controls between the seat— I think.
Can anyone tell me where it attaches to?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-11-2023, 05:38 PM
It's the heater lever switch. When the lever is up the contacts make a ground and the blower in the engine bay kicks on.
Lever -> big washer -> plate that holds the switch -> small washer- > nut for a single lever setup
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 09-11-2023, 05:40 PM
rs6er's Avatar
But how does it attach?
BTW. I removed the blower. Does that mean it's no longer needed?
John
Old 09-11-2023, 05:42 PM
It clips into the plate and that plate locks into a slot on the ebrake. No longer have a blower, no longer need the switch.
Old 09-11-2023, 07:20 PM
