-   -   Where does this vacuum line go? (http://forums.pelicanparts.com/porsche-911-technical-forum/1145963-where-does-vacuum-line-go.html)
maverck 09-08-2023 07:48 AM
On the left side of the engine I saw this purplish/blue line just laying there. It wraps up behind the air box parallel with the red hose.
Any idea what this is supposed to plug into? And yes I know the WUR is incorrect for a ‘81 - working on that!
http://forums.pelicanparts.com/uploa...1694188066.jpg
David Inc. 09-08-2023 07:58 AM
Maybe the distributor vacuum retard? Does your distributor have two ports, and one is open? Is the loose line plugged?
maverck 09-08-2023 08:15 AM
Thanks! I will take a peek.
The line is not plugged at the end.
maverck 09-08-2023 08:49 AM
You were correct. Thanks for the nudge!
http://forums.pelicanparts.com/uploa...1694191613.jpg
boyt911sc 09-08-2023 10:09 AM
Retard Vacuum Hose Connections………..
Originally Posted by maverck (Post 12084901)
Maverck,
The bluish rubber vacuum hose (retard) goes to the lower vacuum port at the throttle body (towards the rear bumper). The upper port at the TB (towards the rear bumper) is for the WUR vent.
Tony
maverck 09-08-2023 06:21 PM
Originally Posted by boyt911sc (Post 12085005)
Maverck,
Tony
Thanks Tony!!
