will 'video' cold idle (will be 3.2 bar) and warm idle (appr. 1 bar) this weekend,
but what I did test in the past - oil pressure sender disconnected: jumps to 5 - resistance at 3,000 rpm was 110 Ohm, did not go up when revs got higher. Even at 5,000 rpm only had 110 Ohm - bought a mechanical oil meter and that meter proved what the oil sender showed even at 5,000 rpm had below value http://forums.pelicanparts.com/uploa...1694630938.png |
I promised some more info (sorry for the delay)
COLD IDLE
http://forums.pelicanparts.com/uploa...1696187586.jpg WARM IDLE http://forums.pelicanparts.com/uploa...1696187635.jpg and all rpm's above...never exceeding the 3.x bar http://forums.pelicanparts.com/uploa...1696187682.jpg |
| All times are GMT -8. The time now is 08:25 AM. |
