Can’t figure out how to attach exhaust bracket
Hey everybody,
my 2.4T came with an aftermarket exhaust and I want to go back to the original. I bought an original Porsche “Banana” and the bracket with P/N 90111115104. I’m feeling a bit stupid because I can’t figure out how the bracket is supposed to connect to the engine. The bolt pattern does not match up with anything obvious. I’d appreciate if anybody could provide a picture to help me out! |
There is a pair of 8mm holes just below the oval in the motor mount
Your replacement fixture faces down to told the muffler seam then band it. Tighten the bands first then the 4 bolts from the heat boxes, then tighten the new fixture. Bruce |
Thank you so much! I didn't see the holes but now I've got it!
| All times are GMT -8. The time now is 11:37 AM. |
