Help identify a line on my airbox
Car is an ‘81SC row. On the drivers side of the airbox there’s a hard plastic line loosely fitted, about 6” long and crimped at the end. I don’t see it in the PET and don’t see anywhere obvious it would have run.
Anyone know what it is/was? Can I remove it and plug the hole in the airbox? The hole is behind the air filter and I assume pulls pretty good suction, so a plug would have to be pretty secure to avoid ingestion. Any ideas welcome, thanks
1978 911SC |
I suspect it is part of your vapor recovery system.
This post by the late Grady Clay (who had encyclopedic knowledge of the 911) may be helpful. I think it is line 6 in the last drawing. https://forums.pelicanparts.com/porsche-911-technical-forum/1133548-fuel-expansion-hose-venting.html Quote:
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 09-10-2023 at 11:21 AM.. |
Thanks Harry, that looks right. Interesting though as there’s no sign of the other line that diagram shows starting at the fan shroud, or a canister I can find anywhere. There is similar material line that’s routed up the left wheel well that just ends open - that seems to route back from the expansion tank in the front left fender. I’ll cut this out and find a good plug for that hole, really appreciate you pointing out those diagrams
1978 911SC |
If you duplicate the 1969 system in this post by Grady it may get you there. Quote:
My mistake, I was looking at the pre-78 diagram. This looks like what mine was before the line was severed. No fumes and no concerns, I think the line terminates far enough back that any vapors dissipate. I removed the line from the air box and will find a suitable plug. Thanks again for helping me narrow it down!
1978 911SC |
Still here
![]() That looks homegrown. |
Sure does look home grown
PCA Member since 1988
From your description it looks like someone removed much of the vapor control system. If so, and you don’t smell gas fumes now, you should consider leaving it as is.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
