Boxster Brake Conversion to 911
I installed a Boxster braker conversion kit on my 72 911. The rear rotors, suggested in the kit, are not a larger enough diameter to make contact with the entire brake pad. The rotor is 3/8ths or 9.525 millimeter short in diameter. I'm using Pagid pads that fit correctly in the caliper.
Anyone had this issue? Thanks in advance. |
Whose kit is it? Have you asked them?
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Yes, it's a Pelican conversion kit.
Looks like it’s made by Tre, or?
Here's a link to the Tre site's page for this kit. Assuming you also upgraded to Carrera rotors, suggest you contact Tre for clarification/confirmation. https://tremotorsports.com/chassis/boxster-brake-kit
