-   -   Issue with SWB spring plates / rebel racing (http://forums.pelicanparts.com/porsche-911-technical-forum/1147052-issue-swb-spring-plates-rebel-racing.html)
jimtweet 09-29-2023 10:07 AM
First SWB I’m working on so bare with me
The SWB spring plate vs rebel spring plate the inner depth is 3/4 different.
Am I missing something? I can’t even get it to go in far enough to engage teeth on torsion bar
http://forums.pelicanparts.com/uploa...1696007059.jpg
jjeffries 09-29-2023 07:41 PM
They look plain wrong, way too much material. I realize that’s a huge statement of the obvious, sorry!
Nico’s Uncle John
jimtweet 09-30-2023 04:46 AM
Nico’s Uncle John
Rebel racing strikes again. I think this may be the straw for me after what I went through these past few transactions with them
Arctic Rat 09-30-2023 06:39 AM
Jim,
Do you have the torsion bars out of the vehicle? I found on my 66 SWB the torsion bars will slide all the way thru to the opposite side of the vehicle. It may be that your bar is inserted too far.
You could simply measure the insert depth on the spring plate and compare to stock ones. Put the snap ring in and insert a rule from the inside to the clip stop.
Install the bar into the spring plate to correct depth, then into the torsion tube. You may find the bar engages just fine. FYI I have Elephant racing SWB adjustable plates on my 66 with their polybronze bushings.
I will say your rubber bushings look to be very thick?
Joe D
75 911s 09-30-2023 07:01 AM
You need the really early spring plate bushing.
(Credit Grady Clay)
These parts pages below are dated 6/67 and 11/67.
#24 901.333.013.02 “Radius arm rear.”
L&R same, ely 911 with removable gummi
#26 644.333.131.00 “Rubber bushing fir
radius arm hub (inner) – up to model ‘A’.”
#27 901.333.195.00 “Rubber bushing fir
radius arm hub (outer) – up to model ‘A’.”
#53 901.333.003.00 “Rear axle radius rod
with rubber bearing. Type 911 from chassis
number 307325 on.”
From this thread:
https://forums.pelicanparts.com/porsche-911-technical-forum/302215-swb-spring-plate-bushings.html
