greglepore's Avatar
wiring/cruise help needed
Was troubleshooting the cruise today. There was no ground connection at terminal 4 of the connector. I popped the back off the connector to find the terminal and s**&^!!!! None of the terminals are captive,and they're all out. Can someone with a Bentley or a good wiring diagram or accessible connector please tell me which wire is inserted into which # on the cruise connector?
A sheepish thanks in advance.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 06-13-2003, 06:27 AM
greglepore's Avatar
Think I got it, by using the troubleshooting protocol. What I have is:
white-3
dbl brown-4
double black -5
black/yellow-6
grey-7
brown-8
yellow-9
blue-10
black/brown-11
empty-12
The only thing I'm unsure of is 5 and 12-the double black lead is constant 12v, and I'm not sure of where it goes. Given the wire length, I assume 5. Can anyone confirm?
Greg Lepore
85 Targa
Old 06-13-2003, 07:16 AM
Heck, I’m only 5 not 71!
targa80's Avatar
This is what I can see from the 1981 cruise control schematic from the service manual.
Pin 5 is BK- Black and connects to terminal 86 on relay and fuse 15 and (+) termianl on cruise control switch
Pin 6 is BK/YE- Black/Yellow and connects to brake light switch.
Pin 7 is GR/BR- Gray/Brown and connects to Tempostat motor.
Pin 8 is BR - Brown and connects to (off) on cruise control switch.
Pin 9 is YE - Yellow and connects to (set) on the cruise control switch.
Pin 10 is BL - Blue and connects to (reset) on cruise control switch.
Pin 11 is BK/BR - Black/Brown and connects to speedometer (A).
Pin 12 is BR - Brown and connects to speedometer (-) and clutch pedal switch.
Hope this helps.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 06-13-2003, 08:28 AM
greglepore's Avatar
Targa 80-thanks, but it changed, apparently, with the introduction of DME. Mine is an 85, diff coding. But thanks anyway.
Greg Lepore
85 Targa
Old 06-13-2003, 08:41 AM
greglepore's Avatar
Greg Lepore
85 Targa
Old 06-13-2003, 09:13 AM
greglepore's Avatar
white-3
dbl brown-4
double black -5
black/yellow-6
grey-7
brown-8
yellow-9
blue-10
black/brown-11
empty-12
Greg Lepore
85 Targa
Old 06-13-2003, 09:16 AM
