-   -   question about 3.2 engines. (http://forums.pelicanparts.com/porsche-911-technical-forum/1147382-question-about-3-2-engines.html)
bickyd 10-05-2023 05:43 PM
Is it possible to take a 88 3.2 engine and put 3.4 low compression pistons and nikasil barrels in it to make a low boost thing. 8 to 1 , maybe 964 cams , maybe mellissa cams, idk.. My shop is almost built and i have a fairly decent 88 911 I want to play with in 10 months or so after my last big money job. I am considering many things but not sure. its at 175 k with a top end done. new sodium valves , seals, turbo tie rods. and lots of other stuff. I know, 3.6 transplant. not interested. i want the work because I have the time soon. i am well read here , have the tools and stuff. Its time to contribute. I want a medium power car with legs to do touring for long miles. My budget is around 50 g Canadian. I know my g50-01 needs some love. she is growly angry bit that will be this winter. I am on it. i have listened to you . stated my budget and ambitions. give me your opinions. i am open to everything.
mepstein 10-05-2023 06:21 PM
Ok, I might be missing something here but in my mind, you would be building an engine that’s not very fun around town but not really needed for long highway miles. Your car should drive all day long at 80-90mph so why spend big bucks to turbo it just to drive highway speeds.
wjdunham 10-06-2023 06:35 AM
Especially when there are a lot of things you can do with a NA configuration.
3.4L P&C (twin plug if you want extra credit), 964 cams, headers, bored throttle body, and an SW chip will get an engine that is plenty fun to drive, easy to get set up and will run for ever.
darrin 10-06-2023 07:03 AM
Love my n/a 3.4 -- don't rule out a 3.6 either - at this point whatever one you'll likely find will already be "well loved" and need/benefit from a full teardown/rebuild/etc.
Rodsrsr 10-06-2023 08:27 AM
If you're going low boost why not keep the stock compression? I run stock compression, with 20/21 grind web cams, headers, with .5 bar boost, and its more than enough power. basically zero lag so it still drives like a normal 3.2 off boost.
If you lower to 8:1 compression you'll need to up the boost which is fine but now its a totally different feel. From what you describe your looking for I think the 3.6 actually sounds like a better fit.
bickyd 10-06-2023 05:42 PM
i hear you but where i live there is no "around town". i live in rural BC in a small town with two traffic lights. it is all highway .its not all about highway cruising. i just want a taste of thrilling boost power.
bickyd 10-06-2023 05:47 PM
I have alusil cylinders , albeit a decent 180 psi, if i am going to transform my engine i dont want it to be on old cylinders. I know i can sleeve them to nikasil, i just dont want to. i will admit i am not too savy with high compression low boost. it does sound tempting. can you share the end horsepower gain?
bickyd 10-06-2023 06:02 PM
sober comment. the conservative guy in me really hears you and you make perfect sense. problem is.... i seen a video of Bill Verbergs , i think it was, car in mexico under full acceleration and i cant get that out of my mind. it was a bad drug.
mepstein 10-07-2023 05:11 AM
Well now that makes sense to me. You want to feel the - push you back in the seat - boost of a turbo. Check out the builds on the turbo forum section. I’m sure there are many tried and true formulas for getting there. Also the guys like promotive, who sell ready to install kits. I would follow a recipe, rather than winging it, so you end up with an engine that makes it more than five miles from home. Good luck with the build.
3literpwr 10-07-2023 05:49 AM
I have a 3.4 (10.3:1) with 20/21 cams and few other bits. It's a good thing overall, but I prefer my 3.0, 10.7:1 GE60 / PMO 46mm way way more. Before I did the rebuild on my 3.4, I was planning to do a turbo build also, but went the route I did. Given the chance, I wouldn’t go the NA route again with my that car.
bickyd 10-07-2023 08:21 AM
I will definitely check out the promotive kits and thanks for the inputs. I am contemplating starting the build in about ten months but the planning stage is now. still finishing my small shop.
Rodsrsr 10-07-2023 08:31 AM
A 3.2 with cams, headers, good muffler, and .5 bar with a decent tune should get you in the 400 hp range, but its not so much the hp, rather the torque from the turbo that makes it so fun do drive. Torque is seat in the pants acceleration. hp is just bragging rights.
spuggy 10-07-2023 12:03 PM
8:1 static C/R doesn't require "low boost", IMO. Factory 3.3 930s came with 0.8 bar and 7:1. With CIS...
I ran 8:1 on mine (with SC cams) for years. Dynamic C/R (all the motor cares about) is altered by cams/timing. The more overlap ("hotter" the cam), the lower the dynamic/effective C/R.
With cams, EFI for good fuel/spark control and good combustion (twin-plugged, COP), 8:1 with 1.2 bar doesn't seem to be "pushing it" to me. I've seen 20 PSI spikes on WOT when fiddling with PID boost control - and detected zero knock.
I agree with Rod 100%; I think the big win of forced aspiration is the relatively massive low-range torque (typically 80% of peak torque around 3000 RPM), flat torque curve and the wide, linear, power band - almost any "decent" (eg designed in the last 30 years) turbo will do that for you. A "modern" turbo could probably do better still (spool faster, flow better etc).
SC cams, although they run out of puff quicker at the top (max by 5500-6000 RPM with torque falling off quickly over 5200 or so), start making power 1000 RPM lower than 964 cams. Almost any half-decent turbo will make positive manifold pressure earlier than the cams really start breathing (my venerable K27/HF made 6 PSI @ 2400 RPM). So they complement each other well.
If shove-in-the-back throttle response from anything over idle interests you, that's one way that works well. Useful more places than just the drag strip - because you don't need to be in the exact correct gear, in a narrow powerband.
Ditch the barn-door AFM in favor of EFI with a MAP/RPM table improves throttle response. 3.4 Nickies come with J&E pistons - lighter than factory. Pauter rods and lightweight clutch equals less rotational mass. It all adds up...
Turbos are great for cruising, but they like taller ratios. You'll really want at least a G50/50 5th for freeway/touring. Perhaps even a total regear (N/A 1st is especially useless with a turbo, and 2nd would be improved by being taller as well, perhaps the G50-02 3rd/4th ratios for close ratio - oh, wait, this looks like an RS box now)...
There's a laundry list of other things you'll want to address fairly urgently if you double the power output of that 3.2. Stiffen the suspension so the tires don't hit the flares when the rear squats under power. 65/35 LSD (and perhaps a billet side-cover while in there). Upgrade the brakes.
You could build the motor with a plan and just increase boost later - it'd hardly be a slug to drive - and this is trivial to do - changing the wastegate spring is easy enough, but even quicker via the ECU... A 4-port solenoid is good to control lower spring pressures/prevent premature cracking of the valve.
mepstein 10-07-2023 12:39 PM
https://forums.pelicanparts.com/porsche-911-technical-forum/1114118-299hp-300ftlbs-my-2-7-turbo-setup-wheels.html
bickyd 10-07-2023 06:04 PM
being honest..... I have to absorb this post. i kind of get it but I need to digest and understand it because i am a person who tries to get to fluency. why i love you guys. thank you.
bickyd 10-07-2023 06:18 PM
[QUOTE=mepstein;12104595]https://forums.pelicanparts.com/porsche-911-technical-forum/1114118-299hp-300ftlbs-my-2-7-turbo-setup-wheels.html[/QUOTE
As much as I would like a steroid ufc machine , its beyond my ability at the moment. sincerely though , amazing what you have done. i have to absorb this as well.
bickyd 10-07-2023 06:43 PM
understood. thanks.
asphaltgambler 10-08-2023 05:33 PM
My build: 3.4, 10:1 w/ modern design JE pistons, turbo oil pump (extra scavenge stage) 3.8 supercup cams, stock heads / valve size with port cleanup, plastic varioram intake where the disa valve is controlled by stand alone rpm trigger box. Programmable MAF on top of OE DME that was double-speeded and custom chipped by Steve Wong. B&B headers / exhaust. This setup is amazing and should be making @305hp at the crank. It pulls smoothly and very strong all the way to 6900. The cams have almost .500 lift with reasonable duration making for great, broad torque curve and real pull from 4500 to top end.
I wanted a build that would make a really good street motor without having to wring it out to get the power out of it. I've worked on an driven a fair amount of these cars and this combination is fantastic. It's not exotic, but the varioram is the key plus using a modern programmable MAF or speed density system. To go past this power level gets real expensive in a hurry. My .02
This was my build, Michael Mount ( Michael Mount Racing) did the machine work and final assembly
mepstein 10-08-2023 05:40 PM
[QUOTE=bickyd;12104779]
This is all Tyler at top tuning. He also works at Canapa, modifying 959's.
Rodsrsr 10-08-2023 06:07 PM
Plus one on the MAF. I use a custom MAF with a split second controller. Yes its old school but it actually does the job fairly well and allows for some on the fly adjustments.
If you decide to go turbo, I would recommend a bolt on .5 bar (7PSI boost) to start, so you can keep your stock 9.3:1 compression. (If its US spec 3.2) I'm betting you'll be happy with this and you can always grow into more. However if you have the euro spec version, I'd probably drop the compression a bit and run more boost. (Yes its a slippery slope).
New Cams, (lots of great suggestions here) replace those lower Divilar head studs with steel, headers with a good muffler (RarelyL8) MAF, (ditching the barn door is a must) For management I use a Protomotive Stage 1 chip with a BEGI rising rate fuel pressure regulator, but there are many other solutions. Decent size intercooler, and you'll need to address scavenge pump. I didn't have much luck with the drain method so I use a Turbowerks electric pump which works flawlessly.
Spooled up in 2nd or 3rd gear, I've put many Teslas to shame with this setup. :D:D :D
One of these days I'll get around to upgrading to a nice stand alone ecu though.
http://forums.pelicanparts.com/uploa...1696816666.jpg
http://forums.pelicanparts.com/uploa...1696816683.jpg
bickyd 10-08-2023 08:04 PM
My DME is a 24 pin so I need to upgrade that as a start. I do not know what double speeded means for the DME. 305 hp is probably the most one could deal with with the present braking system, suspension, and transmission. I have been gathering parts and have all the bushings for the suspension, some synchros, brake lines. i have done the clutch, turbo tie rods. rotors , pads, calipers, shift and steering bushings and a new fan as mine was cracking. i have the notorious growl at low speed in my transmission and a fellow pelican has sent me the g50-01 manual in digital form and that will be this winters project. I had it out already once and cleaned it very well. the oil was clear so it has been changed recently. your recipe is very tempting. thank you for elaborating.
bickyd 10-08-2023 08:55 PM
This is getting to be a tough decision. your car is beautiful. what kind of turbo are you running? I really need a ducktail.
asphaltgambler 10-09-2023 03:15 AM
The early DME's to @"85 was 2K board processing speed. There is a jumper on the board where you can double that to 4K. The late 88 to early 89' went to 8k but the chip pins are different than the earlier ones. The difference is how quickly the engine management adjusts to a modified engine.IE: Quicker revs, flicking throttle. My experience is the 915 trans will handle more HP/TQ than 300+, but not a lot more. The rest of the car will absolutely handle more as it is so well balanced
bickyd 10-09-2023 07:18 AM
I did not know that. Thank you.
Rodsrsr 10-09-2023 09:34 AM
Thanks! @ Bickyd. I'm running a Precision SC6162 that I purchased from a fellow Pelican back in 2011. It's still going strong!
spuggy 10-09-2023 12:24 PM
Cough. Probably because it's not correct.
From iscmhitz's post Permalink in this thread DME Update Questions:
There are different two 24-pin EPROMs out there and not all are 2k. The very first rendition of the 3.2 Motronic used a 2716 with 2kx8 capacity. The base code is located in the CPU and the EPROM contains personalization (maps, calibration, high-level routines)
At some point with the EPROM development moving forward the 27C32 with 4kx8 space and still 24 pins was used by Bosch. The code initially didn't make use of the addition space and two identical 2k-sized copies resided in the 4k EPROM. The base code was still in the CPU. Later versions used the full 4k of the EPROM.
Then once again the the 27C32 EPROM was replaced by the 27C64 EPROM with 8kx8 space and 28 pins. Now the entire code now resides in the EPROM and the internal code of the CPU is disabled.
The jumpers account for the different 24-pin versions of the EPROM. Pin 21 needs to be Vcc for the 2716 to function properly and A11 for the 27C32 IF it is a real 4k later version. The other important thing to keep in mind is that most modern chips now come in a much larger EPROM (27C512) and there should be 8 identical copies inside so the jumpering doesn't matter. The 27C512 is the only EPROM currently still in production. If the chip is in any other EPROM it is a "pull" that has been erased. In other words its an old device that has been sourced somewhere on the used market.
(you can largely ignore Loren/Dave, as usual. Yes, he's technically correct - but contributing little, as he often does).
This is not processing speed, it's setting the capacity of the chip that stores the maps and the Motronic firmware.
Ditch the bloody Motronics already. It's freaking 80's tech - 40 years old. Less processing than your microwave or your toaster, much less your phone. It can't deal with anything "fancy" - much less anything that didn't exist in the 80's. It's like trying to hang on to CIS - why would you do that?
And you need a piggy-back emulator to read/program a Motronic in real time (yes, they exist - a guy here builds them) - which almost any ECU built in the last 20 years or so just gives you out of the box. But this still doesn't let you drive boost control, variable cam timing, exhaust valves etc - or even datalogging.
Rodsrsr 10-09-2023 04:33 PM
I was looking at these once. https://www.vems.com/
Seems to be mostly plug and play. There's a Pelican "Raceboy" who was working with this company at one time. Not sure if he's still around, but he was quite knowledgeable.
bickyd 10-10-2023 07:16 AM
I am aware of the Loren wars and have gone down that rabbit hole. I am sure there was some merit on both sides but it seems like it is productive as discussing the difference between a brace and bit opposed to a power drill. I think I would really appreciate the experience of a stand alone device such as racerboys vems , megasquirt or others. I have set up datalogging in industrial electric applications before. Regardless, I agree in the sense that upping the power in these engines would definitely benefit from a more modern adjustable control. It is common sense to me. thanks for the clarity.
bickyd 10-10-2023 07:19 AM
I am familiar with his offerings and am curious as well if he is still in business. I was always curious why his product was not more successful. variable engine management system. seemed like a winner to me.
