-   -   Knocking noise in reverse (http://forums.pelicanparts.com/porsche-911-technical-forum/1147490-knocking-noise-reverse.html)
209000926 10-07-2023 08:18 PM
Just developed a knocking noise in reverse only in my '84 Carrera. The noise slows down or increases with with the speed of my reverse. Coincidence , maybe, but noticed my odometer only has stopped working as well . Probably two
separate issues but thought I'd mention it. On occasion, the noise seems to go away.
Any idea's on where to start looking?
Michael7810 10-07-2023 08:53 PM
Maybe CV joints.
fanaudical 10-08-2023 07:03 AM
Couple of possible causes: CV joints, something loose in the parking brake assembly, maybe a bearing, hopefully not a worn ring/pinion interface...
209000926 10-08-2023 11:55 AM
Thank you both. I seem to agree with both. Probably will replace entire axle. 101,000 mi.
EC900 10-08-2023 04:32 PM
I had that happen to an 72 Audi 100 (fwd) CV axle bearing cage cracked, but the rattle clunk was consistent.
For what it’s worth, if you have an old cellphone, glue some strong neodymium magnets to the phone case and you have a DYI Go-Pro to attach to the underside, you might be able to record a video to review when doing any one-man exploration and inspections of hard to reach places.
PeteKz 10-08-2023 04:39 PM
If the CV joint boots are not split and leaking, the CV joint probably is still good. They last a looooong time if they don't get dirt inside.
