				3.2 service cost
			About how much is a 3.2 service cost today at a high quality independent Porsche shop? Valves, oil , adjust and tune up.  Thanks , Nick
			I asked the local Porsche dealership for the costs of a service on my SC (only valves adjustment and oil change with self brought oil!) in 2020. They calculated roughly 1000€. Work effort only! Just for your orientation.
			Thomas
	1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.  |
			2022 - MAJOR SERVICE: Oil & filter changed;  transmission oil changed; brake fluid changed & brakes/clutch bled. Spark Plugs, distributor cap & rotor replaced & valves adjusted. Replaced lower valve covers & gaskets. Planed and surfaced upper valve covers & replaced gaskets. Check A/C Freon and operation. $1,768.76 USD (shop rates are now at like $160 hr) Great shop but $$$'s Local AZ shop
			2015 - MAJOR SERVICE: Oil & filter changed & transmission oil changed. Brake fluid changed & brakes/clutch bled. Spark Plugs, distributor cap & rotor replaced & valves adjusted. Replaced alternator housing & fan with new powder coated parts. Replaced valve cover gaskets. $756.74 USD Small one man shop in N. Calif
	Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.  |
			$235/hr at the local dealership.  I needed them to dial in some stuff I couldn’t figure out recently and bit the bullet since the local Porsche indy is unreliable.
	-Mike 1987 911 Carrera Coupe 2001 911 Carrera 4 Cabriolet  |
			looks like i`m affordable in this business i only charge 50 eu an hour;-)..it is actually hobby for me nowadays -beer money
			Ivan
	1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein.  |
			 Behind the Sun
			50 rupees in India
	100 Vietnam dongs  |
you`ll never know ..still trying figure out which state to go to..I`ll see next year
			Ivan
			 PCA Member since 1988
			I'll put in a vote for the Pacific Northwest.  I hear John Wlaker could use a great mechanic.  Part-time of course!
	1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall!  |
			 Red Line Service
	Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA  |
			Back in July, right around $1000 for valve adjust, new gasket set, oil change, filter. —Dave
	1985 Carrera 3.2 • Prussian Blue Metallic  |
 Ivan Peter..it also depends what my better half wants to do and moved to..;-))
			1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 10-12-2023 at 11:32 PM..  |
			Yikes, that's why I do that sorta stuff myself.
	Scottish you know. It's not easy being Scottish.  |
			 Senior Member
			Virginia is nice this time of year
	Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver  |
			France ain't too bad either, but Ivan knows it already.
	Gilles RoW 88 Carrera coupé  |
How do you like wearing a skirt?
