Stock 911SC Exhaust System Stainless???
I have my stock exhaust system at a Electro Polisher. He is a bit weary to process because he is not 100% confident that the system stainless.
Heat Exchangers
Cross-Over Pipe
Muffler
I am 99.1% sure it’s stainless. There has never been rust that I can see. I glass beaded several parts and they have been out in the weather, power washed, ect.
Can anyone confirm that they are stainless steel?
Old 10-23-2023, 09:09 AM
Porsche called the later exhaust systems, corosion resistant steel. I suspect they added NI to improve corosion resistance and they perform much better than the early mild steel systems. They are not stainless steel. Rob
Old 10-23-2023, 03:13 PM
So are you thinking High Nickel Steel?
Old 10-23-2023, 08:37 PM
I think they called it "Aluminized Steel" back then. I don't really know what that process does, but the result looks like hot-dipped aluminum coating. Similar to galvanizing in a zinc bath, but using aluminum. Hopefully, someone with better technical knowledge will chime in.
Old 10-24-2023, 09:22 AM
Thanks guys, I’m thinking Cerakote at this point.
Old 10-24-2023, 08:32 PM
