oil hole thread size question
Working on a 79 3.0. The threads on the tapped hole on the right side case that feed the oil pressure transducer, cam, and tensioner are damaged. I will need to chase the threads with a properly sized tap. Can anyone tell me the thread size to order? I tried various gauges that I have and it seems it could be something like 12x1.0
Thanks in advance for your help!
Old 10-08-2023, 10:28 AM
Thru-bolt……..
Were you referring to this one? The thru-bolt is M12 x 1.0.
Tony
Old 10-08-2023, 04:24 PM
Mark Salvetti's Avatar
Hopefully it's just the threads, and the case wasn't cracked when someone tried to remove the oil pressure transducer on the car.
Mark
1979 911SC Targa
Old 10-08-2023, 10:50 PM
Yes-thats it. Thank you Tony!
A set of taps are inbound.
Old 10-10-2023, 04:01 AM
It's a 914 ...
stownsen914's Avatar
You might be better off with a thread chaser. Or at least make sure you get an "end tap" that has the shorter tapered section. The long taper on a regular tap might render it of limited usefulness in fixing your threads.
Old 10-10-2023, 04:45 AM
Actually I ordered a pair- 1 tapered and 1 bottoming
Old 10-10-2023, 08:00 AM
^^^ +1 this.
A tap is sharp/hard and intended to cut & remove metal - to put a thread where there wasn't one.
Thread chaser is softer & designed to roll/reform the metal that's there to the correct profile without removing any.
'77 S with '78 930 power and a few other things.
Old 10-11-2023, 10:18 AM
