-   -   Unusual Window Switch Issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1147672-unusual-window-switch-issue.html)
LucaScali 10-11-2023 11:25 PM
So my driver's side passenger window switch stopped working reliably, and got worse over a period of months until most of the time it wouldn't respond. Tried cleaning the contacts and when that didn't work ordered a "Made in Germany" switch from ebay.
The new switch looked pretty good, but when installed it worked normally for only a few seconds and then stopped. When I insisted, it began to spark pretty badly, so I assumed the switch was defective. Reinstalled the old switch; didn't work consistently, but no sparks.
Was sent a replacement switch and same story--works for a little bit and then stops, followed by sparks. Still no visible sparks from the original switch.
The obvious thing to do is to test one of the working switches, but the sparks are worrying. The wiring looks like it's in good condition and the fuse wasn't tripped. So what else could be causing the sparking? It's unlikely both replacement switches are bad, but who knows. I suspect based on the condition of both boxes and some scoring on the connections that they're used, but visually they're very clean. I had assumed they were new when purchased.
Is there some kind of relay that could be failing? It's an 87.
proporsche 10-12-2023 12:05 AM
i think you should really look at the window motor ,there could be a short....all this sparking and the fuse did not go bad??
Ivan
wazzz 10-12-2023 02:28 AM
What you don't mention is if the passenger door switch on passenger door works, ie if the window can be lifted and lowered normally with pass switch.
If so, that would rule out the window motor.
Unless I missed the info.
Also, does your driver side window still work? If so, that would rule out the relay, since it controls power to both sides.
dannobee 10-12-2023 07:50 AM
Check the wiring at the door hinge area, where it goes into the car body.
LucaScali 10-12-2023 12:31 PM
Thanks, The passenger side switch works fine. I checked the connection at the door hinge and it's dusty, but fully seated. Haven't removed it.
The driver's side also works fine, thanks for helping me rule out the relay, Gilles.
I guess I'll have to try one of the other switches. Any ideas what could be causing the switches to spark? Could it be caused by frayed wiring somewhere out of sight? The weird thing is immediately after I install the switches the window operates fine for a bit before it randomly stops.
proporsche 10-12-2023 12:54 PM
just a idea, are your wires connected correctly? if i remember... right bottom brown ,left bottom red together connected with right top, middle blue with black on left, blue right....
wazzz 10-12-2023 01:07 PM
Passenger side switch works fine and consistently, so that rules out the motor too.
The driver side switch for passenger side is the one that receives power from the relay and then distributes it to other switches. Don't know if that is of interest in your case.
Anyway here is the schematic for this model year. Hope that helps.
http://forums.pelicanparts.com/uploa...1697141190.png
Synchro Joe 10-12-2023 01:23 PM
Some good info here:
https://blog.*******.com/how-to-replace-power-window-switches-on-an-air-cooled-porsche-911
it's blog.*******.
Synchro Joe 10-12-2023 01:25 PM
eff see pee dot com.............censor nannies here.
Synchro Joe 10-12-2023 01:26 PM
https://forums.pelicanparts.com/porsche-911-technical-forum/184531-power-window-switch-wiring.html
Also here.
http://forums.pelicanparts.com/porsche-911-technical-forum/682755-odd-power-window-issue.html
Mike80911 10-12-2023 02:47 PM
Are you sure that 2 of the contacts are not touching each other or maybe one of the wires is touching the metal brace that holds the switch in place? Is the rubber boot present behind the switch?
LucaScali 10-12-2023 03:42 PM
Thanks, guys. It's wired how it's always been wired, and it worked for years, so I assume it's right. The wires are colored differently. I have red blue on the top and lower left, brown(?) with white stripe on middle left, red on middle right. and ground on lower right.
Now that you mention it, the rubber boots weren't perfect. I wrapped a couple in electrical tape, but the ground wire boot is bit torn. It's possible two of the contacts were touching. But it still doesn't tell us why the switches don't seem to work.
Appreciate the helpful schematic and links. I'll take a look and try again tonight. Maybe I'll remove the driver's side switch and test that. But after my fire episode last month, the sparks really freak me out. I replaced that same switch a couple years ago and it wasn't a problem. It's a bit frustrating.
wazzz 10-13-2023 04:28 AM
For wiring, refer to pin numbers stamped on switch and follow with numbers shown on schematic. Referring to position up down, center, etc. is prone to error.
Also, if you have an ohmmeter, check switch continuity and isolation between pins on the various positions: rest, up and down. Again by referring to the schematic that shows the internals of the switch.
AG81 10-13-2023 05:43 AM
Originally Posted by LucaScali (Post 12107783)
It's an 87.
I went through the same song and dance with my 88. Your dealing with a motor issue. You would be surprised how hard the grease in the motor case can get over time.
wazzz 10-13-2023 06:42 AM
Sure, but he said window motor works fine when operated from the passenger side switch. So that should rule out motor and mechanical issues in general.
AG81 10-13-2023 07:40 AM
Nice....thank's I skimmed the thread.
dannobee 10-13-2023 08:09 AM
Again, check the wiring in the drivers door hinge. Chances are that one (or more) of the wires has frayed or broken in the hinge area (underneath the plastic sheathing) and is making an intermittent contact. Ohm check the wires while moving the wiring harness and opening and closing the door.
wazzz 10-13-2023 09:43 AM
Also remember that on model years 86-89, windows can be operated while the ignition key is off or even removed to the condition that one of the doors or both are open. Not when all doors are closed.
proporsche 10-13-2023 10:15 AM
yup did not read it correctly-not the motor ...as said above must be the wires pinched somewhere
Ivan
911obgyn 10-13-2023 01:08 PM
I had frayed wires in the door, just behind the grommet where they pass through.
