clutch issue on 1977 911s
I noticed getting into 1st gear can be difficult on rare occasions.
the car is still drivable.
Do I need to adjust the clutch cable? or something else?
Old 10-09-2023, 05:00 AM
Adjust the pedal stop back a little bit. See if that helps. Takes a 4mm Allen wrench
it's not leaking....it's just marking it's territory
Old 10-09-2023, 05:38 AM
Rolling to shift into first gear or stopped in traffic or both?
Try check the condition of the shift rod bushing by pulling up the boot and peer thru the inspection hole. You’ll be able to see if it’s broken which is common, if never replaced, get a ball cup bush too. The more they wear out the more the adjustment wanes, same with shift coupler if never replaced.
Old 10-09-2023, 08:35 AM
EC900's questions about when you're having the issues are important. I typically never shift into 1st rolling to a stop.
But to jump to quick, cheap, fixes/checks:
Second the rod bushing, and/or the cup bushing. My SC was tough to get into 1st, and I replaced the cup bushing--night and day difference getting into gear--$18 bucks for shift bushing set through our host. Takes 15 minutes to put in the cup bushing, about 30-45 if you're doing the shift rod at same time. Steps are below.
Shift Coupler & shift lever bushings replacement tutorial made easy-step-by- step
Someone else will chime in with more, but this is a start.
Old 10-12-2023, 06:11 AM
PCA Member since 1988
Third on checking the shift rod cup, bushing, and coupler. If they are still original, and they're not loose, they will be very soon. Replace them. It may not fix your problem, but it will de-complicate solving your problem.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-12-2023, 03:21 PM
