Chain fence eating turbo
'87 Carrera 3.2 seatbelt receivers/receptacles for aftermarket seats
Looking for ideas on how to mount the seatbelt receivers/receptacles on my '87 Carrera 3.2 after installing new racing seats. As it's known, the stock Recaros had them part of the seat rail of the seat itself (seems skimpy).
1. It's not easy to tie into the custom seat rail adapter brackets I made and the seats are only held in with 2 - M8's per side and the sheetmetal is super thin. Not comforting.
2. The trans tunnel sheetmetal is paper thin even when using backing plates/backing washers.
3. The space in the tunnel is super tight to get wrenches in there anyways.
4. Welding on tunnel is too close to lines including fuel.
How did you make it work? I need ideas. Photos even better.
TIA!!!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-25-2023, 10:37 AM
PFA - still need to paint the custom seat rails satin black to blend in with interior in this shot
Old 10-25-2023, 11:11 AM
Brey Krause used to sell a bolt-in bracket that goes under the seat rail
https://www.bkauto.com/category_s/80.htm
Old 10-27-2023, 11:48 AM
I don’t see them…..hmmm
Old 10-27-2023, 06:28 PM
