Rear Speakers for a 1978 SC?
Bought some RetroSound R-463N 4x6 speakers from Crutchfield (https://www.crutchfield.com/S-TM10KFGh9l1/p_068R463N/RetroSound-R-463N.html) after some research here and their fit guide, which is usually good.
Unfortunately they don’t fit: they are plenty shallow but none of the mounting holes are even close, and the mounting frame they come with doesn’t have any holes that align nor is it wide enough for me to Dremel out.
Open to suggestions & recommendations. I don’t need something amazing, just solid 4 Ohm 4x6’s will do. Driving them off a PCCM.
Grey = OE; Black = RetroSound.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic CR calculator: https://dcr.questionable.services/
Old 10-21-2023, 12:53 PM
PCA Member since 1988
Speaker sizes are "nominal" not exact, unfortunately. The ones you bought are significantly smaller than the originals. You might need 5''x7" instead of 4"x6". Maybe even a low profile 6"x9". Call back Crutchfield and tell them what problem you're having. I'm sure they have a larger set that will fit close enough to make work.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-21-2023, 02:00 PM
I think you’re right about 5x7” - the P/N on the existing Blaupunkt’s is a 5x7: https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/790291-blaupunkt-5x7-germany.html
Old 10-21-2023, 02:20 PM
After a chat with Crutchfield I have a pair of Kenwood 5x7’s (shallow as I can get) and a couple of sheets of their custom ABS bracket templates in case I need to fab up mounts against the factory mounting bolts.
https://www.crutchfield.com/p_113C5796PS/Kenwood-KFC-C5796PS.html?tp=93
Will report back when they arrive.
Old 10-21-2023, 03:06 PM
Looking forward to your findings, as my 81SC uses the same speaker. Rob
Old 10-22-2023, 11:54 AM
OK, update after installing the Kenwood 5x7’s:
* They fit!
* They align with the existing fasteners, but the metal frame on the speaker ever-so-slightly interferes with the “corner” (bend) of the rear shelf. This means there’s a bit of a gap between the speaker frame and the underside of the shelf, which means the shelf sits just a little bit higher. It’s * really hard to tell: the four screws on the front of the shelf all line up, it just sits about 1/8” higher.
* I’m going to take them back out next weekend and remove a bit of material with the Dremel to improve the clearance.
In an ideal world there would be 5x7’s that are <= 2” deep but I’ve yet to find a pair, and manufacturer measurements aren’t always reliable.
In the photos below you can see they don’t quite sit flush. If they can sit flush it’ll be perfect.
Old 10-30-2023, 07:16 AM
Hey. Are you installing the speaker form underneath the shelf? Mine were sitting on top of my self. Maybe mine are wrong but that’s what they were when I took mine apart. Mmmm.
Silver 1987 Porsche Targa Carrera
Build thread: 87 Porsche targa! projects tracker
Old 10-30-2023, 09:45 AM
The original Blaupunkt’s were installed from below. The top of my rear shelf is perforated: there are no grills.
Old 10-30-2023, 11:33 AM
Slow old car
Thanks for breaking trail on this- just ordered a set of the Kenwoods, looking forward to some (at least) slightly improved sound!
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 10-30-2023, 12:03 PM
creaturecat's Avatar
Polk Audio makes a decent 5 x 7
Old 10-30-2023, 12:54 PM
Oh interesting. Can you post a pic of your rear shelf.
Old 10-30-2023, 01:34 PM
I would top mount hem and cut out the rear shelf perforated part. That has to absorb a lot of the high frequencies.
Old 10-30-2023, 02:20 PM
Old 10-30-2023, 03:23 PM
That looks super nice
Old 10-30-2023, 03:26 PM
Mark Salvetti's Avatar
In this thread, someone used Infinity Kappa 64cfx 4"x6" plate speakers for the same undermount install: New Rear Shelf - Replacement Speakers?
According to Crutchfield, the undermount depth is just 2-3/16". https://www.crutchfield.com/S-Z3IIoLovm48/p_108K64CFX/Infinity-Kappa-64cfx.html But I also see that they are NLA there. Amazon still has them for $120.
Crutchfield does have the similar Infinity Kappa 463XF, they are more expensive but the undermount depth is even less (2-1/8").
Mark
1979 911SC Targa
Old 10-30-2023, 08:14 PM
