1976 Oil Cap Question
1976 911S Oil Cap.
Should it have rubber or cork washer? Thanks
rubber for sure...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Effect of Inflation…………..
To keep the price down, rubber gaskets not included. Just kidding……
Tony |
Surely it had to come with a California Prop 65 Warning and a Plastic bag is Not a Toy. Money is in the shipping the optional 10¢ gasket. : D |
PCA Member since 1988
FYI, the oil cap gasket is the same size as the fuel sender gasket. Just in case you happen to have a spare one of those sitting around...
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Dang. I hope my car has one of those (fuel tank sender gasket)! Thanks everyone.
