Im undergoing this now, rear bushing & spring plate swap is quite an easy task - not much to mess up! Mine were bad, but not as bad as yours.
Pick up some rennline spring plates with bushings already installed, some new hardware and you’re golden. Lots of videos on YouTube of people doing this work to get your confidence level up. Search greasy finger Porsche, he has a ton of videos. |
The original rubber in these cars is very durable. I didn't replace the the arm bushings on mine. They looked okay, and in order to do that job the first time you have to drop the transmission to get access to those bolts, so it's more of a PITA. I recommend that you first install new spring plates with the rubber bushings that are vulcanized on, see how that works, and save the arm bushings for a time when you have another reason to drop the engine/tranny, then do those if necessary.
Nevertheless, I would still do the spring plates first, see how that works, before tackling the arm bushings. |
| All times are GMT -8. The time now is 10:11 PM. |
