-   -   Can I change my accelerator pedal? (http://forums.pelicanparts.com/porsche-911-technical-forum/1148905-can-i-change-my-accelerator-pedal.html)
rrichar 11-06-2023 02:13 PM
1974 911S
In the process of swapping out my wooden floorboard for an aluminum one I noticed the base of my accelerator pedal was tearing. Looked up the replacement and noticed their is a later model that includes a tab on the bottom. It looks like that is there instead of having the accelerator stopper on the floorboard like the earlier version.
Do you know if I can save myself the hassle of adding the floorboard stopper to my aluminum floorboard by using this newer pedal?
Original version-
http://forums.pelicanparts.com/uploa...1699308575.png
http://forums.pelicanparts.com/uploa...1699308609.png
Later model-
http://forums.pelicanparts.com/uploa...1699308652.png
http://forums.pelicanparts.com/uploa...1699308688.png
Your thoughts are greatly appreciated.
r lane 11-07-2023 06:33 AM
I would use the one requiring an installed stop. Just drill a hole, a 6mm bolt and 2 nuts. That way you can set it exactly. Otherwise the pedal with the tap may give you the correct distance or not.
rrichar 11-07-2023 07:30 AM
Thanks, great idea. That is simpler solution than trying to remount the original stop on the new floorboard.
