Two at once? I’m crazy… 1975 build
With Ruby build on hold for winter months taking this opportunity to get started on the next build.
1975 911, originally yellow,… but not for long. Picked this car up about ten years ago and been stored in my inventory. Had an awful widebody kit on it upon arrival. I’m extremely pleased at how solid this car is turning out to be so far! http://forums.pelicanparts.com/uploa...1699317361.jpg http://forums.pelicanparts.com/uploa...1699317361.jpg http://forums.pelicanparts.com/uploa...1699317361.jpg http://forums.pelicanparts.com/uploa...1699317361.jpg http://forums.pelicanparts.com/uploa...1699317361.jpg http://forums.pelicanparts.com/uploa...1699317361.jpg http://forums.pelicanparts.com/uploa...1699317361.jpg |
Looks like a ton of work to strip it down. Any reason why you didn’t sand blast it?
Looking forward to see the progress |
can't wait to see the final result!
Like I said I reached out to Barry and will report back what he says. |
The only reason I can think that Barry says what he says is to cover if someone is using walnut shells, plastic, glass beads, etc that would not leave the correct tooth in the metal. Like I said above when using 40-60 grit media, then sanding with a finer media to get "tooth" should not be required.
Barry just got back to me, here is his reply.
Epoxy loves blasted metal and yes for 20 years said day with 80 but in the last few years my stand has been using coal slag or sand just clean with 700 and epoxy as sand leaves a nice anchor. All other media must be da'ed with 80. I then asked him if crushed glass was acceptable as well and he said yes. Barry is a really good guy BTW. I owe him a lot. |
And I like a blasted surface because it gets everywhere, especially in little nooks and crannies that nothing else can, and in seams, an important place for adhesion. |
Glass Beads leave a surface you are referring too, crushed glass leaves a surface nearly identical to coal slag or sand. It is essentially the same as coal slag or sand when blasting. Leaves a really good tooth and gets steel "white". Been using 40/60 crushed glass for years. I think it's actually more aggressive than coal slag, it cuts quicker, removes rust faster, probably not as aggressive as sand but I never use sand because of the free silica in it. All of what I'm referring too is in the context of blasting a body. Al OX would be prohibitively expensive to use completely on a body. At least for me. I will go through 15 or more 50lb bags of media when doing a body. |
Thanks for the clarification. Agreed on the sand. I only use Al oxide for Cerakote work and send a body to NH for blasting. They use black beauty I think. The owner operator is a real life Flashdance character, wears a heavy respirated outfit, peels off her hood and is quite beautiful.
You do great work BTW. Have enjoyed reading your posts and seeing the results you get on stuff. :) |
Everyone has their preferences, I'm the same way with all kinds of products. Agree on the justification on equipment purchases. That said I bit the bullet and paid handily for a new screw compressor earlier this year that I want to grow into its capacity over several years.
Thank you, I definitely love what I do, working on some new exciting projects now. |
Interesting! What color are you thinking about for this one?
http://forums.pelicanparts.com/uploa...1699391722.jpg |
http://forums.pelicanparts.com/uploa...1699391882.jpg |
These are for a 5/8" arbor https://www.empireabrasives.com/4-x-5-8-easy-strip-and-clean-disc/ Same company also makes a roloc version as well. https://www.empireabrasives.com/3-quick-change-easy-strip-clean-disc-clean-rust-paint-removal/ Just to reiterate, these aren't cheap HF crap. They work and they last. |
http://forums.pelicanparts.com/uploa...1699407163.jpg
Knocked out a lot of the smaller stuff already while shooting the Ruby car. Love this color in sunlight |
@ChrisHamilton, thanks but enough already with the blasting and epoxy. Mr. Tweet has his reasons; his results will knock your and our collective socks off.
John |
75, my favorite year! Thanks for posting. I like seeing your work. Makes me want to quit my job and just restore these cars in my garage for a living haha.
The gap man. Great work as per usual!
Hi Jim,
I enjoy reading about your cool builds, please excuse me if this has been asked before: Do you build these cars for sale, for customers or just yourself. Thanks, Rutager |
http://forums.pelicanparts.com/uploa...1701735932.jpg
http://forums.pelicanparts.com/uploa...1701735932.jpg http://forums.pelicanparts.com/uploa...1701735932.jpg http://forums.pelicanparts.com/uploa...1701735932.jpg Going through every inch of this wiring, inspecting, and rewrapping |
Impressive skills.
| All times are GMT -8. The time now is 05:13 AM. |
