CBA CBA is online now
Relay (5 total) mounting locations. Any photos?? Please share
Hi all,
I'm mounting 4 Cibie Driving lights each with a relay and also an oil cooler fan.... so I need to mount 5 total relays. It's on a '73 so was hoping you guys had some photos of a clean install that you've done. I'm preferring to mount them by the fuse panel.
Any photos would be great.
Thank you,
Joe
Old 11-13-2023, 04:04 PM
winglesss's Avatar
Doesn't the existing fuse / relay panel have any existing empty relay holes?
Perhaps this JWEST Engineering High Power Relay Set could be rewired to use the existing four relays and place the fifth in an existing empty hole.
1986 911 Carrera Targa
2022 Macan
Old 11-13-2023, 04:47 PM
These bussmann boxes are great. Compact, easy to wire, flexible, and you can buy standoffs to work with them also. There are several options so do some homework before buying, e.g. bussed relay power, bussed fuse power, etc...
https://www.waytekwire.com/catalog/power-distribution/power-distribution-modules/eaton-s-bussmann-15305-2-2-4-mini-fuse-panel
'81 911 SC
'03 BMW M3 (Sold)
'64 VW Beetle, 2332, 48 IDA (Sold)
Instagram: @j_smallwood
Old 11-13-2023, 05:32 PM
