fuel pump in a 78SC
Hello guys
I'm troubleshooting a 78 SC for a friend of mine : fuel pump does run only when key is on starter position, is it normal ?
thanks for your help
Philippe
www.injectionsystemes.fr
Old 11-27-2023, 12:40 PM
The fuel pump will only run in start, then continue pumping if the engine is running. You can bypass this by jumpering the fuel pump relay so it runs continuously.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 11-27-2023, 12:55 PM
Schulisco's Avatar
Yes, jrwilson is right.
Intention: A security feature to stop flooding the (hot) engine compartment to prevent a fire in case of an accident when engine is stalled ...
There are many CIS 911 out there where fuel pump runs when in ingnition on position. This is not correct! There is a greenish terminal on the backside of the sensor plate housing, this is the repsonsible contact. When you unplug it, the fuel pump will also start running in ignition on position, and not as designed in starting position only.
This is the named terminal/switch:
What's the matter? Starting issues?
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 11-28-2023, 09:10 AM
theiceman's Avatar
if someone has bypassed the air plate sensor, there is another problem they are masking.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-28-2023, 09:18 AM
Old 11-28-2023, 10:32 AM
and is there any sensor that prevents from starting engine (starting is uneven on this car) wiring is correct, ground is correct, relays are correct ...
Old 11-28-2023, 10:43 AM
L'injecteur de départ à froid peut débloquer.
Tu veux les schémas ou tu les as ?
Gilles
RoW 88 Carrera coupé
Old 11-28-2023, 10:48 AM
J’ai … oui je pense à ça, thanks
Old 11-28-2023, 11:28 AM
