Engine Bay fuse box
Pelicaners,
1983 911SC
I recently discovered a red wire with a black stripe (pictured below) that had come undone from the engine bay fuse/relay panel. Unfortunately, I do not know where to reattach it. My instinct tells me it belongs to the middle fuse, but I don’t want to make a mistake. There seems to be no wire attached to the upper red fuse. Could someone send me pictures of their fuse box? Especially the wires attached to the right side (towards front) of the fuses.
Many thanks
Old 11-16-2023, 10:50 AM
Old 11-16-2023, 10:52 AM
Here is a pic from my ‘82 SC
Bill
Old 11-16-2023, 12:08 PM
Thank you Bill,
Your car seems to have four wires running to the box with the red wire/black stripe connected to the lowest fuse - a yellow 5 amp.
But I only have three wires and no 5 amp fuses…
I’ll keep looking around
Old 11-16-2023, 03:32 PM
OK I figured it out. The loose red wire goes into the lowest fuse terminal. It is combined with another red wire at that terminal. It works the heater blower motor in the engine compartment.
Thank you again Bill.
BN
Old 11-16-2023, 06:19 PM
