RUFNIT's Avatar
Send a message via AIM to RUFNIT
Porsche Crest Valve Adjustment
I just bought my first Porsche a couple of months ago, and always own muscle cars but never a Porsche. So I am trying to listen to the car everytime I go out to insure it stays in proper mechanical condition. Last time I took it out not sure if its the cold in NJ or what, but seems I hear a rocker arm noise coming from the pass side of motor, is this normal after warm up? Also what is the average cost of a valve adjustment and an oil change run? The car has a modifed BTR ruff conversion in it with twin plugs and all the goodies, the idle runs smooth at 1000 rpm, is this where it should be?
Old 12-17-2007, 09:31 AM
That idle is about right. Most of the cars around that year are set to 950. Not unusual to have ticking valves when warm. The valve adjust and oil change is about 300-500 dollars. This is a great DIY job. Look at all the threads on here to see how.
One issue that comes up alot is the "feel" that the feeler blade should have when the valves are adjusted correctly. This comes up because any looser than .004 inches and you get quite a bit of noise. I use a .003 feeler and don't have to worry about the "feel". Also if you turn the adjuster screw to zero clearance and then back it off 30 degrees you'll be very close. (the adjuster screw is 1mm per turn so 36 degrees is .1mm or .004 inches).
-Andy
Old 12-17-2007, 08:11 PM
Vafri
Look up Backside Method for valve adjust and consider that as well.
Old 12-17-2007, 08:24 PM
This well designed valve adjustment tool from Snap-On would work great IF it were available in 13 mm. Only 12 mm and 10 mm. Too bad.
1987 Carrera 3.2
Old 12-18-2007, 07:01 AM
sig_a,
This is an identical of the above tool. Brand name: Blue-Point YA YA8890 13 MM. Once you used this special tool, you'll probably not do another 911 valve adjustment without one. Highly recommendable tool to have.
Tony
Old 12-18-2007, 07:40 AM
burgermeister's Avatar
How is there room for that giant screwdriver? I needed to use a stubby for many of the valves, especially on the LH (by the cat) exhaust side.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 12-18-2007, 07:45 AM
Monkey Butt Forespin
84_Carrera's Avatar
I remove the pre-muffler on mine to have more room. That tool looks pretty cool. I was actually thinking of trying the alternate go/no-go setup next time around & see how that works vs. mangling a .004" special feeler blade (again). I think I bought like 6 of them last time I ordered valve adjust stuff.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 12-18-2007, 08:10 AM
Dixie Region R Gruppe
w21055's Avatar
Can you use a Snap on Screwdriver and then buy the other portion? Their website shows you have to buy each item seperate and I would love to be able to use an existing screwdriver. That tool looks like the ticket for sure.
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 12-18-2007, 08:52 AM
khamul02's Avatar
Tony,
Where do you get the tool you have pictured?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 12-18-2007, 12:38 PM
onboost's Avatar
RUFNIT..
Assuming from your car discription that it is a Turbo.
- In this case I would suggest that you add $1000 to the cost of the valve adjustment and oil change as stated above.
- As a DIY job if it is a Turbo, it will then be a bit more involved, purely from the standpoint of added items that will need to be remved.
- would think your idle is probably correct.. of course based on what kind of cams you have and your AFR (you did say it was modded)
You're in the right place though... there is plenty of help and support on this board.
Good luck!
RGruppe #180
Old 12-18-2007, 01:16 PM
Valve Tool.......
Originally Posted by khamul02 View Post
Tony,
This is a Blue-Point tool brand distributed by Snap-On. Got this as a Father's Day gift many years ago. One of the best and most treasured tool in my tool cabinet. FYI.
Tony
Old 12-18-2007, 03:41 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
http://www.toolsource.com/valve-adjustment-tool-13mm-p-58868.html?sourceid=froogle
found a similar one here
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 12-18-2007, 04:02 PM
just me
paulgtr's Avatar
http://cgi.ebay.com/Valve-Adjustment-Tool-Porsche-911-R-S-T-RS-RSR_W0QQitemZ300183194571QQihZ020QQcategoryZ418QQc mdZViewItem
and this one too
Old 12-18-2007, 04:04 PM
RUFNIT's Avatar
Thanks all for the help, and yes onboost it is a turbo 911/930. So I will be looking around the 1k range for both? This site is great and everybody enjoy a safe holiday!
Old 12-19-2007, 07:00 AM
w21055's Avatar
Did anyone get one of these from Snap on? I can not find it in their catalog any longer.
1992 Ferrari 348TB
Old 01-15-2008, 09:57 AM
82 911 SC - Ancora Imparo
Reviving an old thread. In case anyone is still looking for one of these, I couldn't find a Snap-On or Blue Point version, but I did find a knockoff version on Amazon:
https://www.amazon.com/Dreyoo-Adjustment-Adjusting-Grinding-Compatible/dp/B0CPJ8TTNG
I've done a VA using the standard wrench and screwdriver, but based on recommendations of folks like Tony, this seems like an easy buy at $25.
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 07-18-2024, 07:22 AM
