Rain Gutter Seam
Anyone have any info on how the rain gutter seam is layered or formed? I am replacing rear fibreglass quarters with steel. I've found some rust that extends all the way up into the seam, and it appears that the top layer belonging to the quarter has rusted through.
I haven't been able to find any pictures or info on how this seam is layered up or how the quarter is folded over or locks with the other layers.
Any info on how a quarter gets attached at the seam would be appreciated. Tips, pics, whatever you've got. I can't seem to find any info myself. Thanks!!
Old 11-20-2023, 05:58 PM
Old 11-20-2023, 05:59 PM
Uncertifiable!!!
Uwon's Avatar
A surprise lurks, I’m afraid….
My guess is that your inner fender panel (double thickness, BTW) is done. Have a look at my Sweet Transplant thread.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 11-21-2023, 05:47 AM
Johan
Maybe, never know until you're in there, but in this case I suspect it's fine. The car is galvanized and relatively rust-free except where the galvanizing was ground off to mount the flares (and of course the rear seat pans).
The rust stops at the edge of where I was removing paint, so I am inclined to believe it is only where the filler and fibreglass layers trapped moisture against the unprotected metal. Who knows, maybe I'm in for it, but I won't know until I peel off that quarter, and I'm not doing that until I know how to redo that seam.
Your car looks incredible, BTW. The shots of your car in metal work and then primer are super cool. Love seeing that stage.
Old 11-21-2023, 06:11 AM
From another pelicans post.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 11-21-2023, 06:34 AM
That is pretty helpful! Seems that the roof is seam sealed to the inner structure and the quarter folds over the edge of both layers. Anyone know if there are spot welds in the quarter panel flange to the gutter? Seems like it would make folding easier.
Old 11-21-2023, 06:47 AM
Full Send Society
Rennch on YouTube (and here) did a gutter delete on his blasphemy build and goes into pretty good detail about how the seam is created and how to unfold/remove it and deal with the result.
https://youtu.be/dxJyU1yox3w?si=JebRU87mCWbaOmL0
https://youtu.be/flnZHoyBX9s?si=Um6ywp-ssuPa531T
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 11-21-2023, 07:55 AM
Cool, thanks. Rennch has a few good shots of the folded seam in there. Anyone have details on how you assemble and form that seam? Sorta looks like you'd spot weld the panel in place at the window/jamb/trunk, squirt some seam seal between the quarter and gutter and then hammer it closed? Maybe some spot welds on the gutter seam?
Old 11-21-2023, 05:43 PM
Editing this post to organize all the useful info I've found. Switched to searching for roof skin replacement and rain gutter delete for info on the seam. As an aside, the rain gutter delete threads are pretty hard to look at...
911 Sunroof Cancelled
https://www.youtube.com/watch?v=3WW7Ol0g078
Quote from RUF on the gutters via Iciclehead in an old thread
The roof of your Porsche is made up of three metal sheets. One over the roof, one over the rear fenders (the C-Pillar), and one along the side, which goes inside the car. These three plates were originally hammered together at the Porsche factory to form the rain gutters. They are not bound together in any other way. Through our gutter conversion, the area where the three pieces fold together is cut off, and then all three are welded together. Welding of the plates greatly increases their strength, and definitely makes the body much more stiff all around and along the roof line. Cutting, welding, and repainting are the only processes undergone in this conversion. No other parts or procedures need to be assembled or carried out.
Old 11-22-2023, 10:14 AM
