Location: Seale, Alabama (25 miles south of Auburn, Al.)
Wur vacuum lines ???
1980 3.0L 911
First of all thanks to everyone on this board that has helped me on this 27230 conversion project so far, I could not of done it without everyone’s input. But I do have a few issues I need help with. 1. There is a vacuum tee on the top of the WUR which should have two lines going somewhere, I need to know where the two lines need to go to? The drawing I have does not show this line. There is a medium sized vacuum hose on the left side of the air box, right above the air intake boots ,where does this hose connect to? The drawing I have does not show this line. There is a vacuum line that comes off of the back of the trottle body and goes to a small plastic tee, one line comes from the tee over to the back of the deceleration valve , where does the other line from the tee need to go. I have a drawing that shows the other hose going to an object but it does not have an ID number beside it. Can someone please tell me what the item is below number 13 and above number 5 . Sorry the Pic is rotated to the right, but you get the idea, I didnt have time to play with the pic. Thanks Rick Last edited by RickKlem; 06-15-2003 at 06:32 PM.. |
I have a 80 sc, my wur has only one vac hose and it goes to the port between the air box and the TB just below the rubber boot, is you car a [USA] model or [ROW]?
Same with mine 81 sc
ben |
Platiporsch
I sent you a PM
Red 1977 911s 3.0L (27230) 2013 Base Cayenne 3.6L |
