walt's Avatar
Replaced Front Shocks - Clunk
About 4-6 months ago I replaced the front shocks and ball joints and finally to around to a drive yesterday. Every minor bump in the road was followed by a clunk on both sides. With the car on jack stands I can lift the wheel and see the bottom half of the strut raise about 1/2" into the upper dust shield and clunk. Where is that play coming from, I do recall installing the rubber bumpers. These are Bilstein struts and inserts. Just wanted to get some opinions before taking this apart.
Walt
82SC 3.0
81SC 3.6
Old 11-26-2023, 12:12 PM
I did completed a full front end overhaul and used Bilsteins HD. I didn’t use rubber bump stops as the Bilsteins have an internal stop and mention this in the instruction leaflet. Did you install the old rubber stops?
Old 11-26-2023, 01:25 PM
wrxnofx's Avatar
If you put the car on jack stands and remove the front wheels, grab onto the strut and try to wiggle it back and forth. Does it do this?
https://youtube.com/shorts/5UvJEtbGU1E?si=ThhyE1KkPP4airKA
I have Boge struts with Bilstein inserts. There is a gland nut that holds the whole thing together under the dust shield. Mine was loose and was therefore responsible for that clunk. Not sure if your setup is the same but that’s what my clunk was.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
wrxnofx's Avatar
I used a gland nut wrench to tighten: https://www.ecstuning.com/b-bilstein-parts/strut-cap-gland-nut-wrench/tms189771/
Old 11-26-2023, 01:28 PM
walt's Avatar
No movement at all in that direction. Different set-up.
Walt
82SC 3.0
81SC 3.6
Old 11-26-2023, 01:50 PM
walt's Avatar
I didn't reuse any rubber parts, only the new bumpers that came with the inserts. I recall a deteriorated rubber piece that fell out but thought it was the old bumper.
Walt
82SC 3.0
81SC 3.6
Old 11-26-2023, 01:53 PM
Been here a while
What was the torque setting for the ball joints?
looking for 1972 911t motor XR584, S/N 6121622
Old 11-26-2023, 02:23 PM
Green or black struts?
206 637 4071
Old 11-26-2023, 02:28 PM
walt's Avatar
Green struts.
Walt
82SC 3.0
81SC 3.6
Old 11-26-2023, 02:36 PM
Originally Posted by walt View Post
Green struts.
I just fitted green shocks in Boge struts and mine didn’t come with any rubber bump stops. Only a little rubber ring on the shaft that is supplied to stop the supplied shock shields from hitting the nut during transport/shipping.
Old 11-26-2023, 04:43 PM
Years ago I replaced inserts on a zcar and had a clunk. Turned out the struts needed a spacer on the bottom. The insert was moving vertically. If you cant find it anywhere else, I would remove the strut and check the vertical play, like a previous post the gland nut may not be completely tight on the insert. I cant think of a way to check that on the car.
Old 11-26-2023, 05:44 PM
Green struts use a roll pin at the bottom to lock in the shock shaft. You may have missed the notch when the roll pin was reinstalled. Old rubber gets trapped in the bottom and keeps the shaft from going all the way down. Stick a punch in the roll pin hole to be sure the shaft is in place before knocking the roll pin back in.
206 637 4071
Old 11-26-2023, 06:03 PM
walt's Avatar
Thanks, I was thinking along that line but I do recall spinning the insert so I could see light thru the hole before driving the roll pin in. I'll check it.
Walt
82SC 3.0
81SC 3.6
Old 11-26-2023, 06:16 PM
I had to glue some washer to the bottom of the shock. It was a hair too short so tightening the top nut did not fully grab the shock in the strut. This was with Elephant Racing shocks and ER had known that this is sometimes an issue.
87 911 3.8l
Old 11-29-2023, 02:01 AM
I think the strut has a notch all the way around it so spinning shouldn't matter. Maybe there was still something in there that you moved around that was blocking the hole, but the strut wasn't bottomed?
1982 911SC
Old 11-29-2023, 08:16 AM
Use a punch about the size of the roll pin after you think the shaft is in the right place and then try to pull the insert out.
206 637 4071
Old 11-29-2023, 08:40 AM
walt's Avatar
Thanks guys, that's got to be it. Just ordered another roll pin.
Walt
82SC 3.0
81SC 3.6
Old 11-29-2023, 10:19 AM
Roll pin seam facing away from the shaft.
206 637 4071
Old 11-29-2023, 01:41 PM
