Matthew “Sometimes the questions are complicated and the answers are simple.” |
Senior Member
All you need now is a good German motorcycle sitting in the garage!
![]() Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Original Owner
You do not glue the tile. It is a floating floor. There is no need to dig out and repair cracks before it goes down. Floor prep is minimal. If you're asking about other flooring types, you're in the wrong thread.
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Senior Member
Bob,
Just helped a friend do tile on his floor. It was not the garage but if you are covering it you should correct the cracks before doing any work on top anyway. They make a fine cement to use in this case and it works very well. I would do this to any garage floor before putting any covering on it. JoeA
Original Owner
Well after three years of good WI use, the Racedeck floor has been pulled up.
The removal of about 500ft in 2x2ft pieces took just under three hours. It will go on the moving truck as is. Why remove it you say???? Because the 911 has been relocated to a home I own in San Antonio (see other thread) which also has a 2-car garage and I want the floor down there and the WI house will be sold eventually. Try doing that with your glue down VCT or fancy pants Griotts epoxy. Muhahaha...another plus for Racedeck... relocatability.
Flexi Tile
I had used epoxy about twelve years ago but it was in need of a re-do. Instead of using epoxy I tried Flexi Tile which is carried by Lowe's. It goes down easy and fast. Best of all; it wears like iron and is cheaper than race deck.
1987 911 Coupe Triumph Trident Track Master History is the lie we all agree to.......... |
Yep, I relocated my Race Deck floor from my dining room to my garage. Quick and easy! Good stuff.
'95 993 C4 Cabriolet Bunch of motorcycles |
