1982 SC crushed jack point
A friend of mine has an issue with his 82 SC Targa and asked for my opinion. I have a fair amount of longhood and 964 experience, but I'm not sure about this one and hopefully I can get some input.
The issue is several years ago his car rolled off his driveway and over a steep embankment. The apex/pivot point hit right at the driver side jack point, stopped there and crushed the rocker and jack tube in an inch or so (sorry no pictures). I'm guessing fixing this would be pretty involved to get it straight again and get the jack tube square again. I'm also concerned what it may have done to the unibody alignment. Any thoughts?
Doug 71 911T |
PCA Member since 1988
Pics would help a lot.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Hard to say w/o any pictures...
In general - this is one of the most sensible points of the 911 body... Don't know of there's a chance to rebuild it, the tube is available as a repair part: https://www.eurospares.co.uk/Porsche/911/911_(1989)/PartDiagrams/801-020/INNER_PANEL?ref=35 I would conserve it first if there are scratches to prevent corrosion which is the final boss at that part of the body. Best is to replace and restore it. Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Full Send Society
I don’t have any experience with this but Mike (Rennch) tackled a damaged jack point in one of his videos… worth a watch just to see the innards
https://youtu.be/YTta0a0aBEY?si=tO7YMzbOrJnxqCsL Sent from my iPad using Tapatalk
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Photos
Here are a couple pictures of the damage I was sent. Not the best but all I could get.
Doug 71 911T |
[QUOTE=Showdown;12145633]I don’t have any experience with this but Mike (Rennch) tackled a damaged jack point in one of his videos… worth a watch just to see the innards
https://youtu.be/YTta0a0aBEY?si=tO7YMzbOrJnxqCsL The video was helpful. I'm guessing at a minimum this will require cutting out and replacing the damaged length of outer rocker and correcting/replacing the jack tube.
Doug 71 911T |
Really, the Renntech video is way over the top for this situation.
Firstly, you need to remove the outer rocker cover to really tell what kind of damage you actually have. So, take the screws out of the black end caps, and literally pull the black rubber out of the channel to reveal the additional philips head screws to be removed. Then go underneath the rockers and remove the screws that hold it to the lower portion, there should be some white plastic spacer that will drop-out.. nothing to be alarmed about. Now you should be able to see the extent of the damage which I believe may be pulled-out with a stud gun.
RGruppe #180 So many cars.. so little time!! |
