-   -   Removing pressed cam box plug (http://forums.pelicanparts.com/porsche-911-technical-forum/1151611-removing-pressed-cam-box-plug.html)
sozaysven 12-04-2023 08:26 AM
How can I safely remove this cam box plug while the motor is assembled? '79 3.0http://forums.pelicanparts.com/uploa...1701707176.png
sozaysven 12-04-2023 08:29 AM
http://forums.pelicanparts.com/uploa...1701707348.png
colingreene 12-04-2023 12:35 PM
To pull it out the back? Drill it greased up, then thread a bolt in and yank?
Dpmulvan 12-04-2023 01:07 PM
Or just stick a long bar/ socket extensions/ broomstick whatever and tap it out. Use a little heat on it first.
proporsche 12-04-2023 02:16 PM
i wonder what is the reason you need to remove it?
ivan
PeteKz 12-04-2023 11:05 PM
Same question. If you don't have to remove it for a good reason, don't.
David Inc. 12-05-2023 05:54 AM
Yeah I'm trying to imagine the combination of needs that would require pulling that plug while also keeping the engine in the car.
Joesmallwood 12-05-2023 05:57 AM
I just did this a few days ago to add a Clewitt Cam Sync. Luckily, I used a screw driver and pressed on one side and the other side popped out enough to grab it with vise grips. .....came right out.
stownsen914 12-05-2023 01:27 PM
Easy with the cam tower on a bench and no camshaft. On an assembled engine (OP's q), I'm not sure how to do it without drilling the plug. Personally I wouldn't be happy to create shavings that would go in the motor. Granted you'd probably be able to get most/all of them out once you removed the plug, but I'd worry I'd miss some and that would be no bueno.
sozaysven 12-05-2023 01:46 PM
Yup, Clewitt Cam sensor. I drilled and priyed it out. But corrosion on housing made it difficult. Thanks for the input. Now I have to drill and tap into the cam end. Terrifying. Any tips from those who have done it?
proporsche 12-05-2023 01:49 PM
you did not say yet ,why do you want to remove the plug?
Ivan
Joesmallwood 12-05-2023 01:52 PM
It was fairly straight forward. I was biting my nails a bit, but after I saw what was behind the plug and how much room there was, I wasn't as nervous. Getting the CAM in position was a harder task, for me. It calls for 120 degree before Z1 on the compression stroke. I had to pull the valve covers off to make sure I knew where that was.
The kit came with a drill fixture. Easy peasy. Collecting the shrapnel afterward was easy with a magnet and vacuum. I took my time and cleaned, cleaned, cleaned. And don't use compressed air. stuff will go everywhere you don't want it to.
