seafood10's Avatar
Do I need this part for a Driveshaft replacement on my 84 Cab?
Appreciate you taking the time to help if you can.
I purchased 2 Lobro 300672 driveshafts for my 84 Cab and am wondering if I need the "Plate" shown in the attached pic from Bentley, it's number 12 in the diagram.
The driveshafts didn't arrive with it and I can't find a part number for it.
Any help with either I need them or not and if so what is the part number would be appreciated.
Also, if needed, is there a particular bolt hole they are supposed to be attached to?
Thanks again!!
84 911 Cab
87 911 Targa
88 930 Cab M505 Slant Nose
62 356B Gone
Old 12-05-2023, 01:45 PM
proporsche's Avatar
here is a Porsche PET.catalogue..for the future..
https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
the part number you need is this,i`m sure you can get it at our host..
Ivan
911 332 191 00
1985 911 with original 502 191 miles...808 198 km
Old 12-05-2023, 02:01 PM
seafood10's Avatar
Appreciate it!!! Forgot to check there.
Are you aware if the placement needs to be mirrored in the same position on both sides?
Old 12-05-2023, 02:09 PM
proporsche's Avatar
same difference;-)
Old 12-05-2023, 02:18 PM
PCA Member since 1988
You should have those "moon" plates on your original drive shafts. Just reuse them. Three on each CV joint. They spread the pressure of the bolts more evenly across the metal collar underneath.
Correction: It looks like the 84's have 4 bolts and two alignment pins on each CV joint, and the later cars have 6 bolts. If you have 4 bolts, there are only two moon plates on each joint.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-05-2023, 02:54 PM
