Loz Loz is offline
Front fender gasket tape
Hi all,
I'm in search of a supplier that sells the gasket/caulking tape that sits along the top of the fender joining face to the body
(70, 911 coupe)
Also once in place and fender tightened, does anyone know the compressed thickness of this gasket? I'm trying to set the gaps.
Many thanks.
Old 12-06-2023, 03:00 AM
PCA Member since 1988
Our host sells those vinyl gap fillers. Just get the gap tight enough that you can't easily pull them out.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-06-2023, 02:01 PM
RV parts shops sell a butyl tape that works as well as the original tape.
Lorne M.
83 SC
Old 12-06-2023, 05:33 PM
Correction to my previous post. I thought you were looking for the vinyl gap filler that goes between the top back of the fender and the body just forward of the windshield. It appears you are looking for the stuff that goes between the fenders and the inner fender/body along the length of that joint. Last time I used 3M body seam sealer. It's held up for 30 years.
Old 12-07-2023, 11:33 PM
Loz Loz is offline
Thank you everyone for help. Much appreciated.
Old 12-08-2023, 08:17 AM
