-   -   Tach Question (http://forums.pelicanparts.com/porsche-911-technical-forum/1151906-tach-question.html)
Rtrorkt 12-10-2023 04:20 AM
Tach Question
Am having a custom face made for my tach. Is it possible to move the turn and high beam indicators to a different location or are the light sockets fixed? Would like to move the indicators down about an inch
jbell959 12-10-2023 05:30 AM
The light tubes are crimped into the case, so moving them is not trivial. Moving them down an inch is not possible because the movement takes up a majority of the space in the center of the case. I'll see if I can find a picture of the inside for you. When I build custom gauges with lights in different places, I typically use internal LED in place of the standard bulbs in the light tubes.
Sent from my SM-G991U using Tapatalk
