Vacuum hose connected to Thermo-Valve
I found a disconnected vacuum hose at the right side of the engine compartment of my 1985 911 3,2L targa.
1. the hose part number is 911-110-953-00 it is on one end -according to the pelican part- connected to the THERMO-VALVE 930 207 231 01 2. Where is the other end of the hose CONNECTED TO? 3. I WAS TOLD IT IS CONNECTED TO THE THROTLE BODY. CAN YOU CONFIRM? 4. WHAT IS THE FUNCTION OF THE THERMO-VALVE? WHAT DOES IT CONTROL? 5. DOES IT CONTROL TEMPERATURE USING THE VACUUM FROM THE THROTLE BODY? I am trying to learn from this forum. THANKS A MILLION. Shiao Fei, Last edited by Shiao Fei; 12-11-2023 at 01:23 PM.. Reason: correct typographical errors |
Still here
![]() ![]() ![]() I believe that's the hose you refer to. |
posted about the same thing on same day, thank you!
_______________________ '85 Black ROW Coupe (trying to put back together) '88 Blue 951 (sold) '84 Blue couple (sold) |
