help with name of this part please?
engine right side behind airbox/oil filler, 2 hoses one down behind engine shroud, the other out thru inner fender wall routes under car to somwhere in front. This latter hose is in piece and I can see where it starts but not where it should end, what is it for and what is it called so I can replace (assuming the factory engineers had a good reason for putting it there :) )
thank you!http://forums.pelicanparts.com/uploa...1702327716.JPG |
Need a context photo, can’t tell where this is.
I haven’t owned a 3.2 in 20+ years, but that sounds/looks like a vacuum canister to me.
Look under the fender for the charcoal cannister.
someone else posted same question same day it seems and I got my answer the hose from the charcoal goes to the gas tank as suspected! No clue how I will install that but here's too trying!
https://forums.pelicanparts.com/porsche-911-technical-forum/1151975-vacuum-hose-connected-thermo-valve.html#post12149699 |
| All times are GMT -8. The time now is 01:19 PM. |
