Missing Cylinder - 3.2 Carrera - Likely Fuel Injector - Replace?
I have a missing cylinder. I have ruled out plugs, cap, rotor, & wires. Suspect it is a fuel injector.
Our host does not carry replacements? https://www.pelicanparts.com/More_Info/93060612000.htm?pn=930-606-120-00-OEM&bc=c&SVSVSI=0603 So I found these...but my sus meter is going off. Only $34 per? https://www.carparts.com/details/Porsche/911/Replacement/Fuel_Injector/1988/Carrera/6_Cyl_3-dot-2L/REPP314301.html I sure would like to replace all 6 of these though. Also, anyone have a walk-thru of the remove & replace procedure?
Frank 1989 911 Carrera Targa 3.2L, all stock 78k miles (as of Dec 2023) "The Machine" |
PCA Member since 1988
Lots of missing info (not to mention missing a cylinder
![]() Why do you think it's a fuel injector? What tests have you run? How did you rule out the ignition system? Have you swapped fuel injectors to see if the problem follows the injector or stays with the cylinder? Next, please put your mileage in your signature line too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 12-26-2023 at 05:32 PM.. |
Addl info: -Yes, a 'misfiring' cylinder. -78k miles. -Recently replaced all 6 plugs as part of regular tuneup/valve adjust procedure. But to be sure I put in the old plugs that I knew worked, same symptom. -Checked all SP wires for resistance. (replaced those at 68k, < 9 years old Beru, no physical damage to them, all snug on plug and dist cap ends) -Replaced dist cap and rotor. -Car had not been started in a couple of months.
Better. Does it miss just at idle, or at full throttle? If only at idle, pour a bottle of Techron Concentrate in the tank and go drive the piss out of it. If the miss is still there, then swap injectors and see if the problem follows the injector. If so, you've isolated it. Two options: have old injectors cleaned and tested. Some NAPA stores offer this service, and probably others in your area. Second option, new injector. At only 78Kmi, I doubt you need a full set of injectors.
Also, is this a new problem, or did it exist before the car sat for several months? Troubleshoot first, then only change one thing at a time. Don't throw parts at the problem. That will only waste money and introduce new variables.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Titanium User
2nd on the Techron - if that doesn’t help, you can pull all 6 and get them cleaned/flow tested.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
I have switched from Techron to BG 44k and had great results on all my 20-40 year old cars. Still use Techron in my motorcycles. All cars and bikes have high mileage and original injectors, etc...
The 44k and a few days of really getting on it (in my 86 911) seemed to make a difference.
1986 911 Coupe 1986 911 Targa |
Great advice thx. Most noticeable at idle. At 3k+ rpm seems to smooth out a bit. Idle is also high, around 1200 now vs normal which for me is 800-900. There is some smoke in exhaust too. I’m a bit afraid to drive it with a misfiring cylinder but will add the Techron and see. This is a New problem - just happened when I started it up this weekend. Before then, she ran like a top. New plugs and a good valve adjust had her purring. |
Might be a sucked in intake gasket. Happens a lot. Gotta pull the intake on that side to find out.
do you know which cylinder?? by disconnecting one spark plug at a time...after spray around that cylinder car cleaner and see.Most likely as John W. said ...could be your problem since even the idle is higher...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thx for the reply Are you talking about these little $1 gaskets? https://www.************.com/Porsche-911Carrera-1989_p-4434-intake-manifold-gasket-32l.aspx Looks like the same material as the valve cover gaskets. So those can break apart and get sucked into the engine? Now I'm *really* afraid to drive it anywhere. Someone else here said "drive the piss out of it" but if it's this gasket vs. a fuel injector, wouldn't that be a real risk? Removing the intake manifold is beyond this noob's comfort level for sure. I'm likely headed to Goldcrest Motorsports. Sincerely appreciate the help tho.
They get hard and crack and if the intake bolts are a bit loose, like most of them, get sucked in, and the air leak kills cylinder performance at idle and real low RPM. There is a plastic spacer with a gasket on top and bottom.
Old post that relates. Dead cylinder number 1 Pic on post 31.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 12-27-2023 at 03:37 PM.. |
Another pic.
I had similar issues this summer after doing the clutch and all of the ‘while you’re in there” items.
Initially I had a really rough idle and it would die. That was a vacuum leak that we diagnosed and remedied. Then, I had a boggy first gear and a verrry mild stumble around 2k RPM’s. After all the DIY troubleshooting I could do at home I had the dealer diagnose a dead injector. Their reco was to ship it out for a rebuilt injector at a shop in CA. Unfortunately I don’t have the shop name but the forum can likely help with that. The dealer was adamant that this was the only option that they would endorse because of unavailable Porsche-spec parts.
-Mike 1987 911 Carrera Coupe 2001 911 Carrera 4 Cabriolet |
Just had this happen to me . Took to shop because of bad mis and idle . Shop found bad sucked gasket on drivers intake. One gasket was installed 8000 miles ago up side down by Porsche shop. During top end. Repaired and mis and idle went back to normal . Repair was just over $1000 for that repair.
