-   -   What is that hole in the filter housing made for? (http://forums.pelicanparts.com/porsche-911-technical-forum/1153127-what-hole-filter-housing-made.html)
bose213 01-04-2024 10:57 AM
Hi. My car is 911sc 1979 Sportomatic. I found the hose which one end is connected to the air filter housing. The other end of the hose hasn’t been connected anywhere. Where should it be connected? Thanks
http://forums.pelicanparts.com/uploa...1704394537.jpg
gled49 01-04-2024 11:08 AM
Underneath is a nipple that a hose connects too. The hose runs forward to a drain. it drains any oil that collects in the intake, mostly from the engine breather.
bose213 01-04-2024 11:47 AM
Thank you Gled49 very much!
boyt911sc 01-04-2024 01:24 PM
Nope………
gled,
The SC’s don’t use this drain feature. Just plug it to keep dirt from getting inside the air box. The pre-SC (early CIS) has a breather hose connected between oil tank and air box and could cause oil residue to accumulate in the air box. So a steel tube oil collector was incorporated in the system. This was eliminated for SC CIS (1978~1983).
Tony
