-   -   dragging Caliper? (http://forums.pelicanparts.com/porsche-911-technical-forum/1153301-dragging-caliper.html)
gerry100 01-06-2024 01:20 PM
dragging Caliper?
1986 3.2, 125K Miles
Spent $3k on brake work about 1000 miles ago but have a recent problem with them.
When the car gets warm ( 10-20 miles) I get a "droning" sound from the front.
When I stop, the LF wheel is fairly warm, the RF is not.
My guess is a caliper binding the rotor.
Any opinions before I go back to my Indy shop?
isby 01-06-2024 03:01 PM
Did your shop rebuild the calipers?
Mixed76 01-06-2024 04:39 PM
I would check wheel bearings if it drones.
Sent from my Pixel 7 using Tapatalk
PTRL HD 01-06-2024 06:52 PM
What brake work was done and when was it done. 1,000 miles could be last year or 10 years ago and that would make a big difference in my opinion of what could be wrong.
If the soft lines weren't replaced as part of the brake work they could have gotten spongy and be causing the pads to not return properly. Especially if they could be original to the car. That was happening on my '84
PeteKz 01-07-2024 12:53 AM
If one rotor is hot, and the other one isn't as hot, then you are dragging. If the rotors are about the same temp, but the hub is hotter than the other side, then wheel bearing.
gerry100 07-14-2025 06:56 AM
replaced with rebult caliper, works fine now
fallingat120mph 07-14-2025 01:37 PM
Nice to see an update...and good outcome.
Erik
gerry100 07-14-2025 02:37 PM
Paid $250 with the exchange.
Could have had a new caliper from Amazon for $50!
