Boxster Brakes Conversion on 1983 911SC
I always wanted to put bigger brakes on my SC. I found an adapter kit with all the hardware and hoses etc. I bought the kit from TRE Motorsports. I bought a set of Porsche boxster, caymen brake caliper set. The front calipers are big big big. The rears seem appropriate size for the upgrade.
Can anyone tell me what I have? The smaller calipers will fit the front calipers brackets. I’m thinking it’s a later year model than what I need.
The distance between the two bolts on the bigger set are 142mm, and the smaller set are 120mm.
Old 01-04-2024, 06:52 PM
Following
Old 01-04-2024, 06:53 PM
Having problems loading pictures. All are under the maximum.
Old 01-04-2024, 06:55 PM
Got it, file size…
There isn’t a porsche part number on them.
Old 01-04-2024, 07:05 PM
I believe the TRE kit is meant for early non-s 986 boxster calipers. Those calipers look like they're newer 718 calipers.
Sent from my SM-G991U using Tapatalk
Old 01-04-2024, 10:26 PM
Thanks SBell, now I need to send them back.
Old 01-05-2024, 11:15 AM
SBell is correct.Our kit only works with standard earlier Boxster. Catalog part numbers are REAR : 986 352 423 01 and 986 352 424 01. FRONT : 986 351 423 03 and 986 351 424 03
These are available new from our host
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 01-06-2024, 03:37 PM
So does anyone have an idea what these are for? These days they could be off a Dodge. There isn’t a cast in part number like some of the other era calipers i’ve seen.
Old 01-06-2024, 03:53 PM
Just based on the color and castings they look like 718 S calipers based on this chart. Measuring the piston sizes should help narrow down what they are.
https://racingbrake.com/caymanboxster-986987981982-718/
Old 01-06-2024, 04:14 PM
