911SC Stuck in 2nd Gear
Hi
Ok, my shifter seemed to lose sense of where it was today and is now stuck in 2nd gear and won't move at all.
It has felt like it has lost "gears" before but it's come back very quickly with a wiggle of the shifter and has returned to working correctly.
I opened the inspection box between the seats and disconnected the shift linkage just to check it wasn't my shifter that wasn't broken, however the rob going back to the gearbox would only move forwards and backwards a very little bit even when I try to really move it.
Could this be as simple as the shift linkage being out of place. Could it be the shift rails are out of alignment?
The shift rob does seem really stuck or jammed but I'm hoping a simple problem and an easy fix??? Is this false hope?
Scott
www.outlawgarage.com.au
Old 12-22-2023, 08:16 PM
Other than this the car has been shifting great.
Old 12-22-2023, 08:17 PM
its definitely stuck and I can't force the rod to move to neutral at all
Old 12-22-2023, 09:38 PM
Slow old car
Check the coupler under the plate on the floor between the rear seats
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 12-23-2023, 12:09 AM
Yep checked that and it was fine. I actually disconnected it from the shift rod going to the transmission and I can not move the shift rod at all.
Old 12-23-2023, 02:19 AM
Its like its jammed and stuck in second
Old 12-23-2023, 02:20 AM
walt's Avatar
Maybe have someone rock the car a bit and try it.
Walt
82SC 3.0
81SC 3.6
Old 12-23-2023, 05:39 AM
It’s very, very hard to move the rod to the trans by hand at the linkage due to the lack of any leverage (that you otherwise get from the shifter!).
You might already know this but just calling it out explicitly.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 12-23-2023, 06:32 AM
Schulisco's Avatar
Stuck in between two gears?
E.g. reverse and another?
Then it _might_ be possible to push it back through the reverse light switch. But heavy to do and you need to apply some force, probably with a lever against the gearbox traverse underneath the car. Shift lever has to be in neutral for that! Dangerous but there are success reports. Remember: Only when being stuck in 2 gears. You can crosscheck it by trying to turn the wheels back or forth. When the gearbox is stuck, the wheels wont turn anymore...
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 12-23-2023, 06:54 AM
proporsche's Avatar
also if you can drain the transmission(get new side cover gasket or good epoxy like grey dirko) and remove the side cover plate on the bottom.There you can with a screwdriver move the fork and slider out of the gear.
Ivan
is that you Scott on impactbumper forum with this problem?
1985 911 with original 502 191 miles...808 198 km
Old 12-23-2023, 07:25 AM
cycling has-been
bkreigsr's Avatar
Has the trans been rebuilt in the last 2,000 miles?
Old 12-23-2023, 10:52 AM
walt's Avatar
Ivan
If you drain the transmission loosen the fill plug first, removal has been a trouble spot for some in the past. 17mm hex key if I recall.
Walt
82SC 3.0
81SC 3.6
Old 12-23-2023, 11:12 AM
I'll try and answer the questions
No history of rebuild and its not been rebuild in 2000km, just don't know if it was ever rebuilt.
It's actually stuck in second as I can drive the car and the clutch works. It's just jammed in second. No gear grinding, just stuck.
Yes the rod is very hard to move, just wouldn't move this the shifter either.
Yes me from Impactbumpers
I suspect when I remove the plate it will be out of alignment. What I don't want to do is a quick fix and get stuck again. So if its out of alignment, and there is nothing obvious what would you do, open the box?
Old 12-23-2023, 12:48 PM
proporsche's Avatar
if you remove the side -bottom cover there is nada you could do wrong.The plate itself had a guiding fork to the shift rod...Just read through the link i have sent you...
After you move the shift fork to idle position replace the side cover and see....
Ivan
Old 12-23-2023, 01:20 PM
If I'm reading this correctly. the shift rod seems to be the problem. as it won't move even when disconnected from the transmission. IF that is the case then maybe you want to check all of the shift rod bushes before tearing into the transmission.
Old 12-23-2023, 03:25 PM
No its in the transmission somewhere
Old 12-23-2023, 08:25 PM
The car has a CAE shifter, that wouldn't have caused an issue?
I'll drop the transmission oil and check the side plate on Thursday and see what I can see.
I drive the car a lot so I don't want a temporary fix, feels like the box is coming apart unless something is obviously loose when I take the plate off
Old 12-23-2023, 08:27 PM
Thought I'd drop an update.
We took the inspection plate off the transmission and it was jammed inside. It turns out the trow needs adjusting on the CAE shifter as throw was moving too far. So time for an adjustment. Seems like nothing else is wrong except for the new shifter not having the correct adjustment when installed. Hopefully this fixes any future issues.
Old 01-17-2024, 03:07 AM
