Replacing rear inner bushes 1980 911
Rear banana trailing arm inner bushes.
Is this doable with transmission in place. Getting new rear big outer bushes for the spring plate and got that sorted but thinking maybe I should do the inner bushes on the trailing arm. Can someone advise if the job of replacing these inner bushes are doable without having to remove any other components on the vehicle, Eg gearbox etc. Thanks Eric |
Here you go.Elephant Racing has the solution.
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKE wjY2Or0ss-DAxX8hIkEHSWwD58Qz40FegQIDRAY&url=https%3A%2F%2Fww w.youtube.com%2Fwatch%3Fv%3D4bilewM7Zsw&usg=AOvVaw 0BbkcLcmTP9d-LRo35kZ-v&opi=89978449 Cheers, Johan |
