911SC Jack Strap
Can anyone take a pic of how the jack strap should look on the top? I am assuming the previous owner mutilated the piece it rests on. There is a very small tab I may be able to pry back on to get the metal slide under, but got a feeling as it goes up, will likely slip out when I go to pull on it. Need to figure what it is supposed to look like so I can go from there. Thanks.
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks, already saw that one. Literally looking for the top of the strap connected to the front of the frunk. Something is just not "bent" right on mine to hold it in place.
lets see your picture..there is a little piece on which the smaller part of the strap is hooked on .Once you get it in bend the strip in
ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 01-21-2024 at 11:46 AM.. |
Pics attached - not much of a bite to try and hammer it back over the strap end.
yup
No pics ... anyone?
Hope these help, from a 1981 911SC coupe.
Awesome - thanks. Now to figure out what happened to the extra real estate on my tab.
