G series Bellypan
I think I need to change my fuel pump on my 2.7s 77 my. Looks like I don't have a front belly pan -weird I seem to have not noticed before !
Can someone post a pic of what my front underside should look like -incan see pics of later cars that leave the fuel tank open but I seem to believe mine should be covered ?
Are belly pans available -a few searches is drawing a blank
Many thks ans also welcome any comments on my fuel pump -it seems to buzz occasionally so time to change methinks before I get stranded somewhere!
Many thks
Andy
Old 06-19-2022, 04:29 PM
Full Send Society
Fuel tank is exposed, skid guard only covers the fuel pump.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 06-19-2022, 04:42 PM
Functionista
manbridge 74's Avatar
I tried to buy one new a few years back but the only one available was what came on later cars 87-89, which is different mounting than 74-77.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-19-2022, 05:43 PM
dlagerstrom's Avatar
Maybe this will help. Although it does not show the skid plate that covers the fuel pump.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 06-19-2022, 05:56 PM
Full Send Society
Here it is, #4 on the PET. It’s found in the section for front axle
The part number is in red.
-Julian
Old 06-19-2022, 06:23 PM
Thks yes I have the protective plate 4 but should there not be a bigger cover over the front end ?
There seems to be some fixing holes unused ?
Old 06-19-2022, 11:31 PM
Skid PLate
Rennline have a Skid Plate. It will cover the fuel tank and fuel pump.
https://www.rennline.com/porsche/911/body-exterior/skid-plates/
1986 Porsche 911 Carrera Targa 3.2 Lt H6
Old 06-20-2022, 02:11 PM
Mark Salvetti's Avatar
No, factory never covered the fuel tank on street cars. Can you post some photos of the mounting points you see? They won't be for a skid plate, but maybe you are missing something else.
Mark
1979 911SC Targa
Old 06-20-2022, 05:04 PM
Does this one replace the factory skid plate that covers the fuel pump and steering rack?
1982 911SC
Old 06-21-2022, 06:17 AM
Yes
Old 06-21-2022, 06:38 AM
Seems like you could remove the protective cover of the fuel pump if you install the skid plate. Saves a little weight and work on accessing the fp.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 01-24-2024, 06:02 PM
Rennine support said you can leave fuel pump cover in place.
Old 01-24-2024, 07:35 PM
I changed mine recently and bought it new. There are two screws on the back side and hold the front sway bar together i believe on my 83 sc
Old 01-25-2024, 04:05 AM
