Fuel air mixture meter/tool recommendations
All
I looking to adjust the idle mixture and have seen posts that mention use of the LM-2 meter to measure CO in the tailpipe. The reading should be between 2.5 and 3%. However, the LM-2 and NGK tool manufacturers only mention having an O2 sensor. Is % CO derived from this measurement or is a CO sensor necessary ? Thanks Tony 1977 911S
1977 911S Irish Green |
I use an LM2 gauge and wide band O2 sensor to set base idle and CO on my 3.2. I remove factory O2 sender and have power clips wired to gauge. Have not installed it in the car because i use it for other cars. Needs to be B4 cat for proper reading.
Here's a link to a CO% to AFR conversion table that has been referenced previously on this site:
https://www.mgexp.com/article/co-to-air-fuel-ratio-afr-table.149#utm_source=alias&utm_medium=mgexperience.net |
Thanks, the conversion is what I looking for.
