-   -   SC Dyno chart? (http://forums.pelicanparts.com/porsche-911-technical-forum/115506-sc-dyno-chart.html)
emarsh 06-18-2003 09:17 PM
SC Dyno chart?
My 1979 SC seems to come on the cams at about 4k rpm. Is this normal? Does anyone have a dyno chart of for one of these?
banjomike 06-18-2003 11:16 PM
my 79 3.0L motor definately starts hitting that sweet spot at 4k. I think that is very typical.
tbitz 06-20-2003 11:00 AM
I think this is from the Bentley manual.
http://forums.pelicanparts.com/uploa...ue%20curve.jpg
tbitz 06-20-2003 11:03 AM
Try again....
http://forums.pelicanparts.com/uploads/sctorque.jpg
Vipergrün 06-20-2003 11:32 AM
Emarsh....any mods to your car? Adding SSI's and dorking with the timing advance and mixture will broaden the range. Before doing any of these it was almost as if I had turbo lag until 4K :)
Superman 06-20-2003 11:42 AM
Yep, very normal. If you advance timing to 35 degrees full advance, the torque curve will flatten a little. I also have installed different cams (20/21, but 964 cams are similar) which have the same effect (flattening the power curve). Yes, your experience is normal. Poor power below about 3500 rpm, screams like a banshee above 4000.
