Fuse box bolt on frunk
Hi all,
Just wondering if anyone knows what bolt is attached to the bottom of the fuse box holder in the frunk.
Mine is missing, I figured to install an alarm at some stage and I'm trying to attach the panel again.
I'm not sure if there are any washers, spacers etc.
If anyone can check, or knows sizes etc, so I can purchase, that would be greatly appreciated.
Old 02-01-2024, 07:03 PM
M4 sheet metal screw with washer …or #6-32 standard nothing fancy. Make sure that white nylon screw retainer plug isn’t striped which might be why the screw backed out and is under your battery, if stripped just upsize screw to #8-32 or M5
Old 02-02-2024, 02:29 PM
Thank you very much!
Old 02-02-2024, 05:15 PM
