-   -   Exterior Door Handle Trigger Disassembly (http://forums.pelicanparts.com/porsche-911-technical-forum/1155607-exterior-door-handle-trigger-disassembly.html)
Wasatch 911S 01-31-2024 05:08 PM
I have my outside central locking door handles off my '87 for paint and cannot get the trigger section off the handle. I have removed the tumbler, central lock switch, and the nut on the stud that the trigger section mounts to the handle, but the nothing will move.
I tried to double nut the stud and almost damaged the threads it is in so tight. Are there any tips on where to pry or way to get the stud / trigger mechanism out without any damage? Is there something else that has to be removed in order to get those parts out?
Thank you for any advice you can offer.
http://forums.pelicanparts.com/uploa...1706749506.jpg
carreradpt 01-31-2024 07:13 PM
The tall piece with the spring should slide right up that shaft and it and the handle should be free. Nothing holding it now except for friction and a bit of corrosion.
Wasatch 911S 02-01-2024 09:53 AM
Thanks Dan T.
Maybe try some heat and more penetrate next? Don't really see anywhere to pry.
