Throttle linkage, do I just pry this off?
EDIT: See Post 9 below for the answer with pictures!
I’m tearing down the engine on my 1984 Targa and I’m trying to disconnect the throttle linkages. All of the others have popped off easily, but I’ve leaned on this one a good bit with my screwdriver and it will not come off. This comes up from the transmission to the back of the engine. In the pic below, I’ve already removed the intake manifold. Do I just need to pry harder? Any suggestions?
I believe you want to turn the locking nut back and then unthread the rod
It has a locking circlip behind the round ball end
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
a 10mm open end wrench works well
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
Targa_PB_78_SC
+ 1 Gives more pry area than a screw driver does
BareRearedRookie |
That’s the one that was frozen on mine (83). I pried it so hard the ball broke off and I had to replace the part that mounts to the front of the engine. The one that says 19473 on yours. It was cheap used on eBay.
Listen to rscotty and Mike ! There is a very small locking circlip (made of wire) that inserts and loops around the ball to secure it. If you muscle it off, there will be needless damage. First rotate the cliip off the ball then pull it out of the hole and you are done.
1986 Targa Guards Red 2021 MT09 SP |
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
A good reason to get the PET diagrams for your year . . good to know what parts you are taking apart and how they go together before you remove them!
Thanks everyone! This was all very helpful and it came apart easily once I knew what to do.
Senior Member
Highly recommend replacing any linkage items with the engine out. My linkage was broken at the bellhousing and it was a pain to replace with the engine in the car. Was able to do it, but required essentially crawling into the engine compartment to get the proper hand placement to re-thread the replacement.
Chris 1988 911 Carrera Targa (driving project started JAN 2022) 1970 911E - Long since gone 1972 911 Targa - gone 1987 911 Carrera - gone Retired FA-18C Driver |
