Defrost light question
There is a square plastic window on the floor of a 3.2 behind the center console. It reads 'Defrost' with a down-pointing arrow labelled On and up-pointing arrow labelled OFF. This seems to be just an instructional light as I see there a single tubular bulb.
What's the meaning of this? Which levers is this thing referring to? What type of bulb is used there?
it's referring to the red levers on the hand brake, lifting them flows air to the dashboard controls (and sends airflow to the defrost vents).
The left red lever sends heat to the left side and the right lever to the right side...What do the arrow symbols for OFF and ON mean?
It's a poor execution of a government requirement -- "on" means both levers up (sending heated airflow to the dash vents and controls) and "off" means levers down (and I agree, the triangles don't really clarify things).
IMO, if it didn't make the car go faster or handle better, porsche assigned the task to an intern -- As for the bulb, if memory serves, it's the same incandescent bulb used for instrument lights -- |
Since it is flat on the floor, I always figured it was not showing up and down with the arrows but forward and back.
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
I removed it when I did the RS carpet install. Didn't really provide any essential information.
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
I agree: "if it didn't make the car go faster or handle better, porsche assigned the task to an intern"
Mine flickers on and off. When I removed the plastic cover there is only one wire - the hot wire....should there be a ground wire too?
1988 911 Coupe Granite Green "Frogger" 1966 912R Coupe Stone Grey outlaw -"'Tilda" 1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter" 1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio) 1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001 Last edited by echecsqueen; 05-24-2017 at 10:34 PM.. Reason: misspelled |
Recreational User
It says DEFROST on it, so I don't see how it can be triggered on by the levers, which only make the flapper boxes open and close. There are, however, some (or at least one, I can't remember) settings on the dial at the top of the heater control unit for defrost. If you set it to a defrost position, does the light illuminate? I can't even imagine what the on-off arrows mean. |
1988 Carrera
Chess girl; you have a bad ground. The light comes on when you turn on the headlights.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
OK I will try to reground it, Shadow. I am guessing that the place where the plastic screw in should be unpainted? Seems like I have a lot of problems with grounding in this car....maybe an evil gremlin. LOL
1988 911 Coupe Granite Green "Frogger" 1966 912R Coupe Stone Grey outlaw -"'Tilda" 1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter" 1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio) 1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001 |
I’m chasing an electrical gremlin as well. 5amp fuse that runs the interior lights, frunk light and clock keeps blowing. Odd that when I put in a new fuse all is well for a short while (no pun intended) and then it blows again.
